Question about Samsung ML-2551N Laser Printer
Outbin full , how do you solve the problem of samsung ml2550 printer. out the problem of "full outbin" hope to help
Posted by zero_alim on
  • zero_alim
    zero_alim Jun 22, 2012
    where I want to see the plastic guide .. hehhe
sahoo_sanjay
    Master:
  • Samsung Master
  • 553 Answers
Dear
The sensor near the exit area of the fusser may have the problem. Mostly the lever spring gets dislocated or broken.
Thanks.
Posted on Mar 04, 2015
1 Related Answer
Anonymous
SOURCE: defeito outbin full da empressora samsung 2550
The plastic paper guide where your paper exits the printer is stuck in the up position triggering the sensor. Push the plastic guide down and it should solve the problem
Posted on Apr 23, 2010
On my HP Officejet 6500A Plus, I am trying to scan from my printer to my computer. When I go under "Scan Menu" on the printer - I only have 2 icons - "Memory Device" and...
Hello.
These extra icons are set up by installing HP's Full software package that comes with the printer, not just the basic driver. This is a option on the disk when inserted, if your missing the disk you can download the full software package from HP's web site
I hope this helps Regards GM
I have replaced all cartridges but still have a solid "red" light.
You need to check with the smart panel software on your computer to figure out what the problem the printer is seeing. There are many things that trigger the red light such as paper jam, waste toner tank full. Hope this help you.
Samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
What do I do when the message "toner exhausted"
If it says toner exhausted and for can't print any pages then you need to purchase a new replacement ink toner for your make and model of printer. Take the toner or the whole printer to a computer shop and ask them for a new toner. They will match it up to the correct one and install it for you. Hope this is very help full.
Thanking you
damnor01
7helpful
2answers
Defeito outbin full da empressora samsung 2550
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
2answers
PJL
1- set tray 1 either to paper size letter or any
then paper type to ANY
2- set tray 2 to Letter and Plain
3- go to file - print - right click on printer- properties- device settings make sure you have the properties correct. ( letter size, any options must be listed here, duplex, stapler etc.. and set to on
4helpful
2answers
Samsung ML2551N: Initialization problem on startup
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Samsung ML-2551N Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
Tom Chichester
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
