Televison & Video Logo
Anonymous Posted on Jun 22, 2012
ILO-32HD Is stuck in Standby
My TV is stuck in standby mode. I've had this problem before and unplugged it and moved it off to the side for a few days after a few days sometimes it goes back to working how it should, I'm just wondering if there is a way I can get new parts or what is actually going on with the TV that is causing this problem. I leave it plugged in and whenever I turn it off I use the controller so what I do really is put it in standby mode and never really power it down. I'm not sure if this helps, but this has happened about three times already and each time I had left the TV in standby mode before going to work. Any help would be appreciated.
  • Anonymous Jun 22, 2012
    Where could I get replacement caps?
Anonymous
Level 3:
  • Master 760 Answers
  • Posted on Jun 22, 2012
Anonymous
Master
Level 3:
Answers
760
Questions
Helped
198847
Points
2272
Look for swollen caps on the power supply and replace if needed. If caps look good, then replace your main board
5 Related Answers
Anonymous
  • Posted on Oct 23, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Anonymous
  • 108 Answers
  • Posted on Jan 08, 2009
SOURCE: tv keeps knocking off to standby mode
It is most likely going to be a defective power supply but there are some other circuits that can cause the problem. I would start by unloading the power supply.
Anonymous
  • 3 Answers
  • Posted on Mar 01, 2009
SOURCE: will not turn on with remote
Read my post on getting a new board for $139.
Dave Rogers
  • 4 Answers
  • Posted on Jan 27, 2010
SOURCE: My TX-47 was/is in power saver mode. A few days
sound like you have the white out feature on the screen saver menu
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 22, 2010
SOURCE: We just moved the tv
Well I think what has happened is that the move has caused a failure, it well may have been bumped or jostled, these units are VERY delicate, and should NEVER be moved without using the protective crating, they came that no-one keeps, for any transport, (It is absolutely imperative that you keep your packaging these days as it should NEVER ever be moved without putting it back into that packaging for travel) they really do NOT travel well at all. This what you describe is a classic situation, we see it all the time in my shop. You have little option but to get a "Quote" for a repair. this is indeed unfortunate, but all too common from "shifted" item. Especially TV's.
2answers
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
1helpful
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Cheers
I have a 52in ilo flat screen television that just stopped turning on. It stays in standby mode. It use to come on and periotically would stay in standby mode. It is now stuck in standby mode.
Check and replace its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Wont Come off Standby
IIC Bus line is busy. Should be a main Digital board problem. Check and replace it.
My Daewoo TV is stuck in standby mode
All you've got to do is get your remote and press the "stand-by button." As simple as that. Thanks
I've had several power cuts lately , now my tv is
Hello rogerstanila,
if you have tried unplugging it for a while and if there is still no change then it could be your main board. Unfortunately to fix this could be costly. See if you can find a repair tech that will do a diagnosis for free. But there has quite a bit of problem LG tv's being stuck on standby especially the LCD tv's, Other than this there is not much you can, maybe changing the battery of the remote and just keep trying to click on and off. If it is plugged into a cable box, try unplugging all of that for a while. Leaving it unplugged for a day won't hurt. If nothing else then it could be your main board. You could replace it but as I said before it could you couple hundred dollars. Hope this some what helps.
-Joe
2answers
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
2helpful
3answers
Ilo 26hd lcd tv
I unplugged mine over night and plugged it back in this morning but it still will not turn on. It is still in standby mode
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
