Subwoofer is connected, reciever is in "subwoofer select:YES" mode but no sound from the sub.
SOURCE: connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
SOURCE: no signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
SOURCE: Subwoofer shutdown
I'm having the same issue as you guys: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever it is) that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Either way... this sucks.
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
SOURCE: Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems? Sqeaky hinges get the oil.
