Question about OKI C Office Equipment & Supplies
Reset oki c5550 to factory default
I need to re set this machine to factory default so i can erase the man codes
Posted by diamondgr324 on
5 Related Answers
pineworks
Clive
  • 4345 Answers
SOURCE: need to know how to reset the oki c5400n to
Procedure:
  1. Power ON printer while holding both the "+" and "-" buttons until “OKIUSER” message apear in LCD.
  2. Press ""+ or "–" button until “ENGINE DIAG MODE” is displayed
  3. Press "ENTER", will be displayed "DIAGNOSTIC MODE XX.XX.XX S-MODE"
  4. Press "+" or "–" button until “NV-RAM INITIAL” is displayed
  5. Press "ENTER" again
  6. Appear "TABLE 1" message
  7. Press "ENTER" until "EXECUTING RESET" message appears. "NV-RAM INITIAL" message will BLINK... IT resets TONER, DRUM, FUSER and BELT...
  8. Power OFF printer, wait 10 sec, and power ON again
To access Service Mode in C9300:
  • Power ON printer with 0, 1, 6, 7 at same time...
Posted on Jan 30, 2010
Anonymous
  • 19 Answers
SOURCE: How to reset the cisco switch to factory default?
When you say you were able to connect to the switch through hyperterm, were you able to login with the enable password? If not, you cannot reset the factory defaults without the enable password. If you do not have this then search on Cisco's site for password recovery for your model switch. If you did login with the enable password, the command to run for CATos is "clear config all". For Cisco IOS, you have the right command with "write erase". When you issue that command, do you get a "Erase of nvram: complete " or an error? Are you issuing the "reload" command after a successful erase? Be sure you answer No when it asks "System configuration has been modified. Save? [yes/no]:" as sometimes this seems misleading and some people think they mean to save the reloaded default. They are really warning you that you are about to loose the old configuration and attempting to prevent you from accidently erasing it. So answer "no". After a successful reload of the IOS you should also clear any VLAN information. To do this, issue "delete flash:vlan.dat" and then do another "reload".
Posted on Aug 29, 2007
networkmagic
  • 139 Answers
SOURCE: Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Posted on Jan 23, 2008
Rick Kasper
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
flexion1
flexion1
  • 737 Answers
SOURCE: how do you reset sharp xe-a302 cash register to factory defaults
Hi.
I would not recommend doing this unless you are certain that it is the cause. I have never had memory corruption in this series before, so I would strongly suggest it is being caused by another factor such as spillage in the keyboard.
Can you tell me exactly which buttons are showing the problem and what happens when you press them. Can you still make sales with the product buttons?
Mark
Posted on Nov 29, 2008
I hard reset my att pantech z990 and it didnt default back to factory settings, It has no settings at all
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 05, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
Got a dbs traxis from sister and need to reset password
  • To reset the password you need to first restore this unit to factory defaults. Then you can use the default code "0000" or have the old code and change it to a different code entering the old code first.
  • To restore to factory defaults follow these steps -
  1. Use the ^ v arrows to select "erase all channels" or "factory default."
  2. Now press the OK button.
  3. There will be a warning display then just press "OK" again.
  4. The receiver is now restored to factory defaults.
Regards, Tony
Jun 14, 2011 | Traxis DBS-1500
I need to erase my pone info or the imf card
Go to Menu
-> Settings
-> Phone Settings
-> Reset Settings
-> if it has any security code Please Enter, otherwise the default code is 0000.
then your phone info and settings are reset to factory default.
if you wont reset data on your memory card just select the format option it will erase all data in your card also
if any problem while doing this mail me [email protected]
Apr 15, 2011 | LG RUMOR Cellular Phone
When i dial a number the phone cuts off and restarts
Please try resetting the phone to default settings and it should work. The default code should be the last 4 digits of your phone number unless you have changed it.
Restoring Phone Memory to Factory Conditions
This returns all settings to their factory default value and erases all user data including pictures, video, music, messages, contacts and downloaded applications stored on the phone.
  1. From the home screen tap MENU.
  2. Tap Settings & Tools.
  3. Scroll th screen up and tap 7.Phone Settings.
  4. Tap 5.Security, You're prompted to enter the lock code.The default lock code is the last four digits of your telephone number.
  5. Enter the Lock Code and tap DONE. The security menu appears in the display.
  6. Tap 5.Restore Phone. A prompt appears in the display asking if you wish to restore default settings and erase all user data including pictures, videos, music,messages, contacts, and downloaded applications stored on the phone.
  7. Tap Yes to reset and restore default settings or tap No to return to the Security list.
Mar 15, 2011 | Samsung Glyde SCH-u940 Cellular Phone
I have a nokia n 81 8gb phone.how i will restore factory settings
Please enter *#7370# on your mobile . this will ask for factory settings reset. Please note that when you restore the factory settings, all your data in the phone might be erased so make sure you take a backup of the data and contacts before you perform a restore. You will also be asked for a security code. The default nokia core is 12345 but please make sure you enter the security code for you phone. Incase this doesnot work follow this.
Please Click the menu key and then go to Settings. In the settings menu, go to security settings. Here you can find the Restore Factory settings option. Please note that when you restore the factory settings, all your data in the phone might be erased so make sure you take a backup of the data and contacts before you perform a restore. You will also be asked for a security code. The default nokia core is 12345 but please make sure you enter the security code for you phone.
Thanks. Please rate if you find the solution helpful.
Feb 22, 2011 | Computers & Internet
How do I reset a motorola vu204 cell phone back to the original factory settings?
You can permanently erase all user data stored on the phone, and reset settings to factory defaults by performing a Restore.
To perform a Phone Restore:
  1. Tap Menu
  2. Tap Settings
  3. Tap Security
  4. Enter your 4 digit unlock code. (Default 1234, 0000, or last 4 digits of your phone number)
    Tap Done
  5. Tap Restore Phone
  6. Tap Yes when prompted with the following message Permanently Erase All User Data & Reset Settings To Factory Defaults?
Note: You will have to dial *228 after the phone power cycles to re-program the phone.
Feb 04, 2011 | Motorola Mobility VU204 Cell Phone
Security code for restore factory settings
12345 s the default security code for nokia....if u forget the code then do one thing..better re install the firmware....all ur settings ll come to the factory setting position...but make sure u have all the contacts as it ll get erased during the process.......
Oct 08, 2009 | AT&T LG CU515 Cell Phone - Black
How do I reset the security code to erase all
Menu - Settings and Tools - Phone Settings - Security
Enter Lock Code (By default last 4 digits of phone number)
Under security select Restore Phone and press OK.
You will be prompted to permanently erase all user data & reset settings to factory defaults.
Highlight yes and press OK.
Re-enter the lock code and press OK.
Jun 16, 2009 | Motorola Cell Phones
How to hard reset a i670?
To reset defaults which does not erase any data or contacts, press menu key and go to: Settings>Advanced>Reset Defaults then select "Reset Settings"
You will be prompted to enter a security code, this code is all zeros then select "yes" This action resets the phone to the factory settings
If you want to erase all data and contacts, perform the steps above but when select advanced, choose "Reset All" instead of "Reset Settings" the security code is 000000. This will wipe the device and contacts.
Mar 30, 2009 | Nextel i730
Cannot go back to default greeting message
According to the Operating Instructions for this machine, chapter 7.1.1. says that by erasing your recorded message, the machine should be set to play the pre-recorded greeting message again. And I guess you can then go on and try to record a new message, hopefully it will be more successful this time. I don't have this machine myself, but I wish you good luck!
Jan 03, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
1,685 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
