Question about Casio Fx-992s Scientific Calculator
How to remove sci command for casio fx-992s - Casio Fx-992s Scientific Calculator
4 Related Answers
sincroe
SOURCE: Finding Rational Zeros of Polynomials on a Casio FX-115 Sci. Calc.
I'm not sure how to do x4,
but from -5x3 and on yes. Mode-5-4, and insert coefficients.
Here the solution:
1. 1.927
2. -0.413
3. -2.514
Posted on Dec 02, 2008
k24674
  • 8091 Answers
SOURCE: I have fix and deg on my fx 992s and I am only
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Posted on Mar 03, 2010
Testimonial: "Thank you!!!!!!!!!"
  • 102366 Answers
SOURCE: my casio fx-992s is showing
The DEG is merely indicating that the angular mode is set to degrees. If you want to change it to radians or grads, press SHIFT MODE and make your selection.
Likewise, the FIX is merely indicating that the calculator is displaying numbers in fixed decimal notation. If you're not seeing any digits to the right of the decimal point, then you're in FIX 0 mode. To change it, press SHIFT MODE. You can choose FIX and the calculator will prompt for the number of digits, or you can select NORM.
Posted on Nov 29, 2010
Elessaelle
Elessaelle
  • 122 Answers
SOURCE: i want to remove rad
For removing SCI symbol press following keys Shift-->Mode-->8-->1.
You can't remove RAD symbol, you can only replace it by DEG or GRA.
Posted on Sep 05, 2011
How do i calculate Rec on fx-992s casio calculator?
Rec? Conversion from polar to rectangular coordinates ? You need and a radius (length) and an angle (Rec (r, theta)). Make sure the angle unit is the one you want: degrees or radians.
Dec 27, 2016 | Casio Fx-992s Scientific Calculator
How to make my degree button work?
I am sorry but the image does not show any Degree button.
To set the angle unit you have to press the Mode button twice before you arrive at the angle unit configuration. See the screen capture below.
Jan 16, 2014 | Casio Fx-992s Scientific Calculator
How do i make the degree button of my fx992s work?
Remove sci mode from Casio fx-82SX
Press MODE then select one of the FIX or NORM modes.
Sep 18, 2012 | Casio FX-115ES Scientific Calculator
I want to remove rad and sci symbol from casio fx-901 calculator display
Aug 22, 2011 | Casio FX-115ES Scientific Calculator
Casio fx 992s when i try to do simple calculations like 1.33360 - 1.33041.....the answer is 3.19 and other little numbers in the top right. i dont get this or like this. i want a proper 5 decimal...
It sounds like you need a manual for your calculator. You can download a scanned copy here, and it will explain what all the keys are for. For now, here is the way to set the calculator for a five decimal place display:
  1. Press the MODE key three times. A menu offering choices of FIX, SCI or NORM will appear.
  2. Press the 1 key to select FIX mode. The message "0~9?" will appear.
  3. Press the 5 key. This tells the calculator to display five digits after the decimal.
This mode setting will hold until you change it to something else, or when you turn off the calculator.
Spend some time reading the manual and work with the calculator. It's a powerful tool with a lot of capabilities. Thanks for using Fixya!
Oct 08, 2010 | Office Equipment & Supplies
Where is the comma on the casio fx-992s
You can download the manual at Search-Manual-Online.com, It is in a PDF file, so you can save it on your computer.
May 02, 2010 | Office Equipment & Supplies
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Mar 03, 2010 | Casio Office Equipment & Supplies
Casio fx-82es significant figures
it should...
it can be found by SHIFT then MODE then SCI is the one you want to choose
Jan 07, 2010 | Casio FX-300MS Calculator
How to switch off the REG and Sci function
press MODE then select CALC then COMP to remove REG.
press MODE again select DISP then NORM1 to remove SCI.
May 20, 2009 | Casio FX-115W Plus Calculator
Casio Fx-992s Scientific Calculator Logo
556 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
