SOURCE: 2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
SOURCE: acer aspire laptop
xp or vista i found anythin for vista please look here
http://www.geekstogo.com/forum/BSOD-STOP-0x0000008E-
Acer-Travelmate-laptop-Vista-t197324.html
I have an Acer Travelmate 8215WLMi which has today developed a problem!
Previously
it was running alright using Vista Professional but when I try to start
the laptop, it lets me log-in using my password but then gives me the
blue screen of death.
The only specific information on the blue screen screen is as follows:
"STOP: 0x0000008E (0xC0000005, 0x821570E6, 0x8D06694C, 0x00000000)"
I have searched google and the microsoft help site but don't seem to be able to come up with any solution.
I
am able to access safe mode and have been led to believe this may point
to it being a problem with software rather than hardware?
As an
aside, I also want to restore my laptop to factory settings but am not
sure how to do it. The laptop came preinstalled with Windows XP (no
disk was provided), which I upgraded using the Acer Vista upgrade disk.
I am unhappy with vista and would prefer to go back to using XP but do
not have an XP disk. I believe there is a keystoke sequence that can be
used to factory restore an Acer machine but I am unsure what it is -
can anyone help?
Hi Katiesam
Turn off auto run, auto play by following these instructions:
http://www.kb.cert.org/vuls/id/889747
You may have inadvertently downloaded some malware from an email or a flash drive....
Once
you've done the above, restart your machine and see if you still get
the error. If not, you should run a scan with your antivirus program and
an online antivirus such as Eset online scanner
http://www.eset.com/onlinescan/
ESET Online Scanner: System Requirements
http://www.eset.com/threat-center/cac4.php?page=requirements
ESET Online Scanner: FAQ
http://www.eset.com/threat-center/cac4.php?page=faq
ESET Online Scanner: Help
http://www.eset.com/threat-center/cac4.php?page=help
SOURCE: Error message: Physical memory dump
The error code is pretty general and could indicate a few problems. You can try the solutions posted here: http://www.updatexp.com/0xC0000005.html .
SOURCE: system crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
SOURCE: my acer laptop 4736Z's memeory dumping problem
HELLO..if you convert the memory and it is you experienced these problems may be the memory you bought is not compatible with laptop, can the FSB memory is high and the laptop is low and they do not match the FSB, or try to install a new OS / windows...GOOD DAY
