Question about SanDisk Sansa e270 MP3 Player
Driver for sandisk sansa e270 for mac OSX
Wont recognize my computer
5 Related Answers
Jean Sintulaire
  • 759 Answers
SOURCE: sansa e270
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Mar 27, 2008
Anonymous
SOURCE: SanDisk 2GB Sansa e250 doesn't turn on
Can I help me?
I have sansa e250.I format sansa.Now,my computer doesn't recognize with USB and Sansa no turn on.
Who you know.? can you help me?
Thank
Posted on Mar 31, 2008
Anonymous
SOURCE: my sansa wont boot up
fisrt turn off the sansa then try turning the hold switch ON hold down the rec button at the same time you turn the power on
Posted on Sep 24, 2008
Anonymous
SOURCE: can't install my sansa e270 driver on vista ultimate
Just to piggyback: on the Sansa website, download the driver for the e200, which is what the e270 is a part of. My e270 works fine on Vista now.
Posted on Jan 08, 2009
Anonymous
  • 11 Answers
SOURCE: My pc is not recognizing my sansa mp3 player clip model 1GB. Do I
Here is the manipulation to be done to remedy this.
To begin, open Windows Explorer and click the Tools /Folder Options /Display. Look in the list "Hidden files and folders" and check "Show hidden files and folders."
  • Right click on the icon "My Computer" from desktop and then click Properties. Then click on Hardware then Device Manager.
  • Right click on the line marked "Unknown Device" and click "Update Driver".
  • Then in the wizard to update the hardware choose "No, not this time."
  • Click "Next."
  • Select "Install from a list or specific location (Advanced)".
  • Click Next.
  • Then click on "Do not search I will choose the driver to install".
  • Choose from the list of hardware USB hub.
  • Click Next.
  • Click on "Disk".
  • A window opens. Then click "Browse", go to C: /windows/inf and select usbstor.inf and click Open.
  • The path of the selected driver will appear in the previous window. Click "OK". The driver will be installrd and you have a line called "Device USB Mass Storage".
  • Choose from the list of hardware "Storage Volume".
  • Click "Next."
  • Click on "Disk".
  • A window opens. Click "Browse", go to C: /windows/ inf and select volsnap.inf select and click "Open."
  • Then the path of the selected driver will appear in the previous window. Click "OK". The driver will be installed and you have a line called "Generic Volume".
Posted on Jan 11, 2010
Not detect in my computer sansa e270
download ITUNES software from enternit that is free so that your ipod recognize to your PC.
Apr 01, 2010 | SanDisk Sansa E280 MP3 Player
My computer has stopped recognizing my player, Sandisk e270 worked fine for ages!!! Been to MY Computer right clicked.clicked on manage, can't find it
Reset the player (see "Settings" menu). Verify that the USB cable isn't damaged. Try other USB ports, especially the ones on the back panel of your computer. Try a different computer.
Feb 08, 2010 | SanDisk Sansa e270 MP3 Player
Not recognized on my computer. running xp
go to settings on ur sansa, go to usb then change it to MSB. that should fix it
Aug 12, 2009 | SanDisk Sansa e270 MP3 Player
Where can i get the sansa e270 driver... my system does not recognize the player.. it says found new hardware wizard
Well I found this... http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
That should work, but I can't say for sure...
Jun 24, 2009 | SanDisk Sansa e270 MP3 Player
Can not transfer video from my coputer to sandisk e270
You must use the Sansa Media Converter to transfer videos. If the video is DRM-protected (many of Real's movies are), it may not actually convert. But if the video is DRM-free, then the Sansa Media Converter will perform the conversion and load the video onto the player. The Sansa Media Converter may or may not recognize the Real file format, so you may need to download an additional program such as Riva FLV Encoder to convert the Real video to AVI format first - then the Sansa Media Converter will recognize the file.
-Tha Mp3 Doctor
Feb 13, 2009 | SanDisk Sansa e270 MP3 Player
Installing trouble with Sansa e270
http://www.drivers.mrjuan.com/driver-5949-sansa-e270.html
Go to this link and choose the OS your computer is running off of and the software should be on there somewhere for download.
Dec 26, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 ....computer no longer reads content of sansa
Well, the reason you can't see some of the songs is because they are in a hidden folder. To access the hidden folders, you have to go to computer, then folder options, and check unhide hidden files and folders. If you go back to sansa, you should see a light colored folder that is titled music.
Dec 08, 2008 | SanDisk Sansa e270 MP3 Player
Can't install my sansa e270 driver on vista ultimate
Go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Thank you
Computerrep
May 03, 2008 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
