Question about Canon PIXMA iP90v Printer
Flashing error lights upon turn-on
8 amber blinks then 1 green---repeats adnauseum
This is a waste ink counter error and the absorber needs to be replaced and the counter reset. I need to knos the reset procedure and the number to use to order the absorber. This is a canon iP90v.
thanks
Posted by erychtar on
5 Related Answers
hanafi
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
Anonymous
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
Anonymous
SOURCE: Reset Waste INk Canon MX318
help me please....!!
may printer error 5B00
Posted on Apr 01, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: canon pixma ip90v waste ink absorber is almost
It's not a problem, just a fact of life. The old ink has to go somewhere and when the drain pack is full you need a shop to replace and access the service mode to reset the counter. It involves removing all the top covers, lifting out the print engine and replacing the drainpack.
Posted on Jan 11, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 04, 2008 | Canon Office Equipment & Supplies
Green light flashes 8 times
IF THIS IS A PIXMA IP2000, then
Eight flashes = Waste ink absorber* almost full. The printer has a built-in waste ink absorber to hold the ink consumed during Print
Head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the R R ESUME/CANCEL button to clear the error so printing can continue for a while.
A longer term RESET IS possible BUT without changing the blotters, you're exposed to ink eventually running out of the printer without warning but... if you still want to continue, here are the reset instructions. Good luck!
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green.
Now press the resume button 4 times and then the power button. You've just reset the waste ink counter. Good luck. Just hope it doesn't come back to bite you!
Aug 31, 2014 | Canon Office Equipment & Supplies
Lights flashing 7 times
Never heard of 7 flasjhes.
Five flashes = No Print Head Installed. Install or re-install.
Aug 31, 2014 | Canon PIXMA iP2000 Photo Printer
.error 1700 says waste ink absorber nearly
(In waste ink absorber replacement, perform
the EEPROM information print to identify if the main and/or platen
waste ink absorber should be replaced. After replacement, reset
the applicable waste ink counter(s).)
Waste ink counter reset See “Service mode operation
procedures” below.
The following 3 methods are available:
- Resetting the main waste ink counter (0%)
- Re-setting the main waste ink counter
value to 50%
- Resetting the platen waste ink counter
(0%)
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
<Waste ink counter reset procedures>
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan ltr
Jun 24, 2010 | Canon Office Equipment & Supplies
My Canon PIXMA iP 1600 - Waste Ink Absorber Almost Full what do I do?
1. Turn off printer
Then download this tool unzip it and start it.Select the connected USB port number from USB PORT.Click LOCK RELEASE, and select the applicable model name in SET DESTINATION.In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Oct 14, 2009 | Canon PIXMA iP1600 Printer
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
The number of the Reset
button pressing
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cost of Cleanng/replacing the waste ink absorber-for a Canon pixma 780?
This is just a worthless error message. You can just reset the waste ink counter to fix this issue.. The reset instructions are given below..
1. Turn off printer
Let me know how it turned up..
Regards,
Eagle338(Sai)
Sep 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Aug 13, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP90v Printer Logo
237 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
