Question about Reddy Heater-30-55,000 BTU Variable
My Reddy Heater shoots out excessive flames
My heater is like a flame thrower. Flame comes out a couple of feet no matter what setting it is on. It also makes a loud noise to the point where you can't hear people talk. One thing I notice is the plate inside has only one ring of holes in it and the parts manual shows multiple rows of holes.
Posted by bwatford5297 on
3 Related Answers
Anonymous
  • 193 Answers
SOURCE: My reddy heater will run for a little bit then
Clean the lens of the photocell - electric eye- Check pump pressure on back of motor at pipe plug
Posted on Nov 14, 2009
Anonymous
  • 52 Answers
SOURCE: my blue flame heater has yellow tipped flames?
yes air to fuel ratio is off
Posted on Dec 19, 2009
Anonymous
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
When I release the ignition switch no matter how long hold it before releasing the flame goes out but the fan remains running fine. Is this a thermostate problem or another issue.
There is a flame sensor on these units that senses that the flame is lit....it can become defective over time...it should be right on the housing right where the flame comes out of the nozzle and should have 2 leads coming off it...you can contact the manufacturer to find where and who carries parts for your model.
Jan 18, 2011 | Reddy Heater-30-55,000 BTU Variable
Is there supposed to be flame coming around the cone of a 115,000 btu reddy forced air kerosne heater?
no. the flame should be behind the cone. If it passes the cone, this means that there is too much air. simply turn the air pressure screw until the flame no longer comes beyond the cone.
Nov 27, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
55000 reddy heater unsteady flame
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
FLAME PROBLEM WITH REDDY HEATER RLP100, HAS BAD FUMES WITH LITTLE FLAME
Hi it sound like the burner /ports a blocked trycleaning them out should improve flame
Jan 17, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-30-55,000 BTU Variable Logo
136 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
