Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
I have my router activated to give up to 3 guests access to the internet with password, I have the main connection to my personal laptop. I am connected and stay connected without problems but my guests get connected but constantly kicks them off and gives them a no internet access problem they have to reconnect every 5 min yet I remain connected. what is wrong? thanks
I'll venture a guess that some file sharing or such activities are going on, using up the three guest IPs. I'd suggest upping the number of guest access in the router to something like 10, then taking it down from there. Perhaps don't broadcast SSID if you want to ensure someone is leeching your internet bandwidth, and share the name (SSID) only with your friends/guests.
Posted on Jun 03, 2014
SOURCE: cisco 1760 router had not accept password i think
you will have to reset it or recover it. It can be a lengthy process, here's the howto on cisco's site for a 1760 router password reset/recover:
http://ciscosystems.com/en/US/docs/routers/access/1700/1760/hardware/installation/guide/trblsht.html
Posted on Apr 06, 2010
SOURCE: My cisco router won't talk to a d-link switch
Make sure you have DHCP setup. Check the settings on your router and make sure everything is configured correctly.
SOURCE: Using Cisco Router E1000. Wireless laptop will not
Frequent wireless disconnection can be caused by different factors such as:
a-2.4 GHz interference: Your router may be operating on
the same frequency as your cordless telephone system (or even your
neighbors'), or other nearby equipment. Try to change your router's
channel to 1 or 11 (the default channel is 6) and restart the wireless
computers.
b-Physical obstructions: Your router or wireless
computers may be losing connectivity because of physical obstacles such
as walls and floors. Try to move the equipment to different locations to
find a better link.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause
conflict with other Linksys routers within your network range. We
suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
1)To change the router's SSID or the wireless network's name, click here.
2)To change the router's channel, click here.
3)To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable
after performing the steps above, it could mean that your firmware is
corrupted. For instructions to reload or upgrade firmware, click here.
I think is better to configure your router again, so you can set the router to keep alive every time.
Posted on Nov 07, 2010
SOURCE: I have tried connecting Cisco linksys router but
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Posted on Feb 21, 2011
SOURCE: I'm trying to connect a remote desktop equipped
The setup disc for the router only needs to be run once when setting up the router to work with your internet provider and modem/router. You can try putting the disc in your desktop computer and reconfiguring the router.
Posted on Feb 28, 2011
Oct 08, 2015 | Linksys Cisco Wireless Router E1000...
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Sep 09, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
Aug 18, 2014 | Computers & Internet
Dec 19, 2013 | Computers & Internet
Mar 10, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Dec 08, 2011 | Linksys Computers & Internet
Feb 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Jul 16, 2010 | Linksys Wireless-G WRT54G Router
Feb 12, 2009 | Zonet Computers & Internet
Jul 20, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Aug 02, 2017 | Cisco Linksys E1000 WirelessN Broadband...
196 people viewed this question
