Question about Samsung YP-Z5 MP3 Player
Samsung YP-Z5 has locked up while playing. Cannot exit, or change, or shut it down
MP3 locked up while playing, and was completely charged. Unable to unlock it or make any changes, and it no longer plays.
    New Friend:
This is the same problem I have! Try cleaning the resistive touch-pad (located under the sticker in the center) and the ribbon wire connecting it (green and flat with 4 strips of metal in it) with a bit of Windex or rubbing alcohol. The pad has various wires of different resistances in it and when certain groups are connected (touched) their resistance combines. For this to actually work, the pad has to be super clean and free of any corrosion.
This picture shows the buttons and the ribbon wire:
samsung YP-Z5 has locked up while playing.  Cannot - 8_14_2012_9_20_48_pm.jpg
The pad is under the sticker with the arrows on it:
Posted on Aug 14, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Posted on Nov 22, 2007
Anonymous
  • 70 Answers
SOURCE: samsung YP-Z5
From my experience this is a hardware fault with the touchpad. Luckily you can buy a faulty player on ebay and replace the touchpad - make sure the fault on the faulty one is not the same!
The player is is easy to take apart and the touchpad easy to replace.
Posted on Dec 22, 2007
Anonymous
  • 70 Answers
SOURCE: Samsung YP-Z5 can't scroll
This is a common problem with these players. It is a hardware fault with the touch panel. It is probably why they were replaced with new models very quickly afterwards. The touch panel is a complete unit added to the device.
If you can get hold of a faulty unit on e-bay (with a working touchpad) you can easily replace the the touchpad without damaging any part of the mp3 player as it easily unscrews.
Posted on Feb 05, 2008
Anonymous
SOURCE: MP3 driving me mad
i cannot turn on my samsung 1G mp3 yp-1 after last recharge.
How can i turn it on or reset it?
Posted on Mar 17, 2008
DerMullerMan
SOURCE: SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Posted on Jun 07, 2008
MP3 driving me mad
Mar 15, 2008 | Samsung YP-Z5A MP3 Player
Samsung YP-Z5
Nov 20, 2007 | Samsung YP-Z5 MP3 Player
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
YP-Z5 Not Charging
How many hours did you charged the unit before this issue occur? because if you h8ave charged the unit for longer that 4hrs, then the problem is you have over charged the unit, if so your unit needs service.
Sep 02, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Down scroll
Try reseting the player. It might not work all the time, but this was the first time my down scroll ever locked up on me, and the reset button fixed the problem. It might just be a temporary solution, but at least it's something.
Aug 09, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Jul 04, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Keeps restting itself
Firstly, try "re-setting" the Z5 (ie micro switch) first. If this doesn't resolve, then firstly save a backup of all your files...then use the 'format' function (ie open My Computer, then open the YP-Z5 folder, then look for the Format function), which will clean out your entire memory, including hidden files. Then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your Z5. Always update your Z5 with latest firmware (appropriate with your Windows OS). Good luck.
Mar 06, 2007 | Samsung Yepp YP-Z5QB MP3 Player
Samsung YP-Z5 MP3 Player Logo
198 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
