Barring password.....bar incoming calls
Hi since there is no reply let me give you a trick,download and install Download CallBlocker:Block useless call and many other games, wallpaper, ringtones and phone apps on your Nokia phone to your phone.This application helps you to reject unwanted call.But this feature can use only when you have GPRS/Internet connection.Thanks for visiting
SOURCE: incoming calls barred
Goto settings there you will see a option "Restore to factory settings" .Try it and let me know if this fix the issue.
SOURCE: what is incoming call barring password of nokia
to block incoming calls press *33*0000#. to unlock press #33*000#
SOURCE: Call Barring Password - NoKia 6300
call barring password normally is 0000 or 1234 / 00000 or 12345
SOURCE: I can't call. "Number barred"
Go to your settings --> Security Options and check your call barring service. Remove all the numbers you want from that barring service.
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
security......call barring service .... incoming calls yet i only want to block one call
