Question about NEC Dterm Series I Dtr-8d-1 / 780039 Black 8 Button Spe
NEC Dterm Series i voice mail not picking up.
Tried "speaker, 43, then phone extension" and all I got was rapid busy when keying in the 43.
Posted by Kathy on
Joane Epting
    New Friend:
Try speaker 43 then 3000 speaker
Posted on Jul 29, 2013
How do I set up call forwarding on a NEC dterm series i
On an Elite it's SPEAKER 43 + the extension you are forwarding to. These phones work on about 6 different NEC systems, so this may not work for you. Oh, cancel for this code is SPEAKER 44.
Dec 22, 2014 | NEC Lands Phones
How to divert calls
You can forward all to another extension or to an outside number. You can also forward busy/no answer to both of those, but then it'll cancel your busy/no answer to voicemail. Speaker 41 plus ext or 9 plus outside number will set CF ALL, speaker 43 will set CFBNA, 42 and 44 to cancel. These are the default codes for NEC pro II, Elite, and IPK. The DTP phone also works on other systems that have different codes.
Jul 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
How do you take out voicemail from the phone so call forwarding can be processed?
I'm not sure that you are phrasing the question correctly. How can I bypass the voice mail box would be a better explanation.
If you take out the voice mail box it will go to the main greeting. Call forwarding to voice mail is call forwarding being processed. Is there somewhere else you would like it to forward to?
If you are just trying to delete your mailbox then you need to know your system manager info. If you do email me at [email protected] and I can help you further.
Call Forwarding Options:
From Port 1
Find port 01 or Tel 01 by pressing feature 4 from the lowest extension # in your system. Once you have found port 01 dial either of the following:
Call Forward Busy No Answer
Speaker 45, enter the extension you want to forward i.e 103, enter the destination, another extension perhaps 107 and speaker.
Call Forward Busy No Answer to an outside #
Speaker 45, enter the extension you want to forward i.e 103, press 9 and enter the destination phone # and speaker.
To Cancel Call Forward BNA
From port 1: Speaker 46 and the extension #
Call Forward All
Speaker 47, 103, enter the destination extension 107 and speaker.
(You will notice the Feature light flashing after this operation)
Call Forward All to an outside line
Speaker 47, 103, 9, enter the destination phone # and speaker.
To Cancel Call Forward All
From port 1: Speaker 48 and the extension #
Nov 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Voicemail not picking up even though voice mail is set up
from each phone hit speaker dial 42 than the voicemail pilot number. could be 200 depends on system programmer. your busy forward no answer is not setup.
Jul 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
Name Display NEC DTerm Series i
It is changed via MAT or MOC programming. See you PABX Technician.
Mar 27, 2009 | Lands Phones
Voice mail not answering
Press speaker, 43, xxx, speaker. "xxx" is the number of your company's message box, if you know that.
Jun 13, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Nov 30, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm Series I Dtr-8d-1 / 780039 Black 8 Button Spe Logo
Top NEC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
