Question about OKI C Office Equipment & Supplies
OKI B410DN ERROR FATAL 120
SOLO MARCA OKI B410DN ERROR FATAL 120
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
Jeff Hughes
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
Anonymous
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: how to reset drum for the oki B410DN
Most of the OKI printers have a fuse installed in the drum to do the reset. If you google the drum reset kit you can find the drum kits and fuses.
Posted on Jan 14, 2010
Anonymous
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Service call fatal error 023E
Indication of a faulty ROM on the CU pcb.
Sep 02, 2014 | Oki Electric Industry OKI B410dn Digital...
Oki error 449
Paper can not be fed
because the cassette of the
Tray 1 or the duplex unit is
extracted.
Install the cassette of the
Tray1 and the duplex unit.
Apr 04, 2014 | Oki Electric Industry OKI B410dn Digital...
OKI B410dn drum life
Every Oki B410d printer, Oki B410dn, Oki B430d, Oki B430dn, Oki B440dn, Oki MB460, Oki MB470, Oki MB480 are contacting the module of the Oki 43979002 drum and fuse with chip developed in the module imaging unit through joints being in the bottom part of a printer like in a photo. Eksploatacja Oki B410 pochodne drukarki reset kasowanie bbna
Jan 28, 2014 | Oki Electric Industry C8600n Led Printer
Okidata C7300 Fatal Error 120
Service call 120: error
PU unit fan motor
1. Is fan in PU operating?
NO - Replace Fan motor.
YES - Replace engine control board (K7N).
2. Error reoccurs after replacing fan motor.
Jan 18, 2011 | OKI C7300 Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
How to reset drum for the oki B410DN
Jan 14, 2010 | Office Equipment & Supplies
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | OKI C5150n Led Printer
320 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
