Dear Terry,
The speeds on your unit are fixed,
Good Luck,
JP
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
SOURCE: Hi, just picked up the
I removed the turntable belt and reinstalled it. Now, the 33rpm albums turn at the speed they should. Thanks
SOURCE: Sony PS-LX250H is running slow
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
SOURCE: jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
SOURCE: would like to know if
Yes, it can. Just connect the RCA LINE OUT from it to the Line IN from the pc with a cable like
http://www.amazon.com/Dayton-3-5RCA-12-3-5mm-Stereo-Cable/dp/B000F7P7EW
Then to pick up the sound just use any recording program you want. I use
http://www.roemersoftware.com/free-sound-recorder.html
