Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens With Macro Logo
Question about Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens With Macro
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Posted by rj saunders on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Tokina Master
  • 102,366 Answers
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Posted on Jun 20, 2012
4 Related Answers
Anonymous
  • 37 Answers
SOURCE: tokina 35-300mm af zoom lens
Unless you have extensive experience, this is best left to professionals. If you didn't spend much, then you could "learn" on it, but if it is something you really value...don't do it.
Posted on Nov 03, 2007
Anonymous
  • 667 Answers
SOURCE: Tokina Lens hood BH 779
B&H Photo/NYC has them in stock: B and H
Posted on Jan 24, 2008
Anonymous
  • 111 Answers
SOURCE: Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro (www.bibblelabs.com) does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
Posted on May 20, 2008
Anonymous
  • 4090 Answers
SOURCE: i have the tokina atx 280 pro lens but no hood,
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
Posted on May 19, 2010
1helpful
Need adapter tokina 100-400 f/4.5 minolta to Canon Digital SLR
You need a Minolta to Canon adopter. Because the Tokina was made for the Minolta in the first place. Be aware that even with the adopter, there is a very great chance you always have to focus manually, because the lens can be fitted on the camera, but the electronics will not be compatible.
That is one of the things you almost aways lose, when using lenses from a different make.
I need a new front element for a tokina 12-24mm, where can I get one from and can I do the repair myself?
Do you have a lens collimator and other equipment needed to ensure proper alignment of the element? If you don't, send the lens back to Tokina and have them replace the element.
3helpful
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Part# BH775
3helpful
I have a Tokina lens which says SD 35-200mm 1:4-5.6. The serial # is 8508870. What can you tell me about it, like what camera brand it fits?
Hello. The SD stands for Super Low Dispersion glass. It's a type of glass which is supposed to correct a lot of common light-transmission errors that naturally occur with optics used in this manner. All companies use "special" or "proprietary" methods of producing their respective high-quality lenses. The 35-200 tells you the focal length(how much zoom capability) you have. In other words, 35mm is considered a mild wide-angle lens while 200mm is approximately equal to a 10x pair of binoculars. Tokina makes lenses for a wide variety of cameras. There should also be a letter designation stamped on the rear of the lens mount. "O" for Olympus, "M" for Minolta, "N" for Nikon, "P" for Pentax, etc. Sometimes, there are 2 letters showing that the lens will fit cameras from 2 different companies.---Rick
2answers
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
1helpful
Have a Panasonic FZ50. Puchased a Tokina 3x Telephoto today. Screwed the Telephoto on with the correct adapter ring.Changed the Menu setting to Tele. Go to take a Photo and i can only get the conversion...
Most add on lenses are designed to be used at a certain focal length, a zoom should be used (is most effective) when you are completely zoomed out, (really why would you add a zoom lens then not zoom all the way) a wide angle lens should be used with the zoom all the way in (cause your getting the widest angles). As far as quality, you really shouldn't have an issue except you may get black edges depending on how big the end of your lens is. Good luck
What does my zoom lens fit?
The lens fits in vivitar, pentax,cosina cameras
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
1helpful
Tokina 35-300mm af zoom lens
Fixing aperture blade mechanism
if your not a trained qualified tech,never try to open your lens,you may spoil it all, since you need refocusing.
Top Tokina Cameras Experts
Steve
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
