Can not get the wand tip to pull out to the low pressure setting to apply soap
SOURCE: I have a dewalt 3750
I worked at a tool rental center while attending college and learned many tips and tricks about Dewalt and other brand pressure sprayers. Your machine probably has a 13 hp honda and has max pressure of about 3500 to 3700 psi. Most of the problems that customers had were engine related due to severe working conditions including totally wet engine /plug, wet air filter, and or other problems that were easy to remedy. We would set the pressure regulator to minimum pressure and explained to the customer how to increase the pressure as necessary but only after the engine was completely warmed-up to running temp to prevent engine stall. Your machine has a throttle lever between the tank and carb that should be set to max if you are going to set pressure at or neer max range. Most cleaning jobs do not need much pressure. Use lowest pressure to get the job done. Your engine developes around 13hp at about 3600rpm. If you want to maximize the life of you sprayer, then use your machine at about 70% of capacity or about 2000 to 2500 range that will allow you to run your engine slower increasing lifespan. Your sprayer is likely rated at 4 gallons per minute so make sure that the tip is that capacity. The tip has the size stamped which would show the fan degree and flow in gpm. The wrong tip, say a 3.5 gpm will strain the engine to point of stop because the smaller tip increases pressure. Most engine stall is due to high pressure setting on new machines. Lower pressure when warming-up machine and use max pressure rarely when necessary to max life. Please email for other information/questions or simple tests to determine faulty parts, good luck.
Posted on Jan 30, 2009
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
SOURCE: pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Posted on Jul 27, 2009
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Posted on Aug 25, 2009
Feb 24, 2015 | Garden
Jun 28, 2012 | Garden
Jul 01, 2011 | Karcher 2500 PSI Pressure Washer
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Jun 15, 2010 | Karcher G3025OH Pressure Washer
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
Sep 07, 2009 | McCulloch Garden
Aug 09, 2009 | McCulloch FHH18A Electric Pressure Washer
May 03, 2009 | Garden
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
74 people viewed this question
