Need a manual so that I can take apart and clean.
Hi, if you look inside the grill from the back side, you will see there are small snaps inside near the edge of the cover. The snaps go around the entire cover and are about 3-4" apart.
I used a flat tip screwdriver to get push the tab up from the back and the inside of the grill. When you push up the tab a bit, then slide a small flat tip screwdriver on the outside lip of the front grill. You will have to do this all the way around until the cover snaps off. Putting it back on is a breeze because it just snaps together.
***AS ALWAYS SAFETY FIRST !! NEVER WORK ON ANY APPLIANCE When it is plugged in !! ***
Hope this helps.... =) Hopefully you won't need the manual and im pretty sure they won't tell you how to take it apart either.
SOURCE: Lakewood WC 8 floor fan; blades need cleaned. How
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
