Question about Panasonic TH-42PX60U Television
Connecting ipad2 with hmdi cable, tv freezes and releases every few minutes
Streaming videos to ipad 2 works fine. but when connected to a hmdi cable and to tv. tv screen freezes up and then plays again off and on, every few minutes tv is a panasonic TH-42PX60U and works good
Posted by Melvin Shaughnessy on
David Duncan
  • 760 Answers
These two products are not compatible.
Posted on Jun 20, 2012
5 Related Answers
Anonymous
SOURCE: Panasonic TH-42PD25
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for $60. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthrea... if you want, contact me by replying and I can mail you the jig temporarily for $10 plus S&H. You'll save money and it worked for me, i just need it back.
Posted on Sep 10, 2007
Anonymous
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
Anonymous
  • 47 Answers
SOURCE: Can't play my PS3 through the Panasonic TH-42PZ800A
your HDMI output is bad
Posted on Jun 14, 2009
Anonymous
SOURCE: Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
Posted on Jun 16, 2009
PanamanNE
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
Tip
Top 7 iPad apps for watching video
Do you have some problem when watching videos on iPad? No worries, I've got a round top 7 best iPad apps for watching video, to help you watch your favorite televisions shows and movies to the utmost.
Netflix App - Top 1 video watching iPad apps
Netflix is probably the coolest iPad apps for watching videos and TV shows. The official Netflix app is free, and allows regular Netflix subscribers to manage their DVD and streaming queues. It allows you to stream the same shows and movies available online.
ABC App - Top 2 video watching iPad apps
The ABC player is the next best iPad apps for watching video. The app is easy to navigate either by show, or in the super-convenient calendar view and the video quality is crystal clear. We tried it out and this video watching iPad apps looks great and works well, at least over WiFi.
YouTube App - Top 3 video watching iPad apps
The iPad's built-in YouTube App for iPad is largely a scaled up and bigger-screen version of the iPhone app, and it works exactly like you would expect YouTube to work. Searching for videos is simple, and the interface is easy to use via touch screen.
Air Video App - Top 4 video watching iPad apps
Air Video enables you to stream video (converting it on-the-fly, if necessary) from your Mac or PC. The main limitation of this iPad apps is that it's free version only shows a few items(randomly selected) from each folder or playlist.
Hulu App - Top 5 video watching iPad apps
Hulu doesn't yet offer its own app, although one is rumored to be in the works for Hulu's long-rumored subscription service. Once this hits, we think the iPad will truly have access to most of the TV and movie content that people want to watch on a daily basis.
Ustream App - Top 6 video watching iPad apps
Ustream is another popular service for watching live videos on the iPad. The company plans to bring its Ustream Viewer app to the iPad, offering functionality similar to its existing iPhone application. Users will be able to browse live streams and then interact with them via Ustream's chat and social stream features.
Flixster App - Top 7 video watching iPad apps
Flixster shows you movie times at your local theaters and lets you buy tickets. It also shows ratings from Rotten Tomatoes and lets you play trailers for upcoming films. Sometimes it can be annoying, like when it pops up an advert for a film that you have to dismiss before you can use the app.
Note: iPad does not support HD video, if you want to watch HD video on your new iPad, you need to convert video to iPad with some video converter.
on Sep 28, 2010 | Computers & Internet
How can i put a hmdi cable into my goodmans gtv42p tv
then you TV is not equipped for HDMI but u can use Component cables they work just as well. on back of the TV you should see several plug in's the RED,WHITE and Video are called RCA , they will work too. but the next one u look for are labeled Comp. (purple, red and green) they are larger and thicker that the RCA , plug those into you Satellite receiver or Blu Ray Player. Then go to ur TV and view it using the matching video stream..
Jan 07, 2015 | Goodmans Televison & Video
Computer to tv
just connecting is not enough to view pc on tv, you need to switch the display by pressing the fuction key, diffrent on each system
Jan 08, 2013 | Compaq Computers & Internet
How to connect ipad to my tv
You will need Apple Composite AV Cables to connect the iPad to your television. The cables can be purchased online or at your local Apple store.
You can also stream your iPad to your television if you have an Apple TV by using Apple's Airplay.
Hope that helps!
Aug 10, 2012 | Apple iPad 16 GB 3G Tablet PC
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
Can connect iPad and Mac Powerbook laptop to my Sony 36
Hi Jim
It's not on a channel, it's the RGB or VGA inputs. (check your "Source" menu on the TV). Works fine here. When the units are talking to the TV the screen on the unit will go blank. One thing. When using your iPad, tghe battery will go down faster than normal.
Feb 20, 2012 | Computers & Internet
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Streaming Video Freezes sound continues
You have the wrong screen resolution. Lower your resolution and it will work fine.
Mar 30, 2009 | Acer Aspire 5920-6727 Notebook
Most streaming video run through flash media and you must set the feed setting in micromedia flash players to your download speed or it will be intermitiate it is security because virus and trace bugs can be encoded into flash media and tag your info evento the point of remote logging soo all you have to do is go to control panel and go to internet setting and allow the download in your sucurity setting that it .try it let me know what happens.
Mar 30, 2009 | Dell Latitude D620 Notebook
Panasonic TH-42PX60U Television Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
