Question about Stihl Saws
The cutter works but loses power at times - Stihl Saws
Posted by lewiscollin on
  • lewiscollin Jun 20, 2012
    stihl ts400 . The cutter works but loses power at times
Brad
  • 425 Answers
That could be caused by a number of things. A compression test would help narrow it down. You could also pull the muffler and visually inspect the piston and cylinder for any scoring. If you do a compression test look for 90psi or more. If around 60 or less then there is the problem for sure. Between that it still could be a scored or worn cylinder and piston or bad rings. Igniton and fuel issues could also be the problem so you need to do some trouble shooting to narrow it down.
Posted on Aug 25, 2012
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
How do i clear jammed cutter blades
Does the shredder have a reverse button ?
If it has, just switch between reverse and forward a couple of times.
If that does not work it may have to be dismantled and the cutters turned by hand as you pull the paper out. Disconnect the power first though.
Dec 17, 2014 | Office Equipment & Supplies
When i start stump grinder it works fine. when i start grinding a stump it pops, backfires and loses power. any suggestions?
Hi it looks like i had the same problem with my 252 and we replace the wire harness and got the problem fix.
Nov 24, 2012 | Vermeer Sc 252 Walk Behind Self Propelled...
My motor is working but the top cutter will not move, I've taken it apart but it still wont move the cutter at all. The only time the motor moves the top cutter is when I unscrew it. What should I do?
The front tension is too tight loosen it a bit this may help, if not you need to send it in to have it check if the motor is still working with full power. check Mannys-Sharpening.com They can help.
Jan 28, 2011 | Andis T-Outliner Hair Trimmer
Husqvarna_24hp_54_yard_tractor
when was the last time you took a look at the cutter blades,,or serviced the cutter deck? if the cutting blades are blunt or rounded off it will stall the engine stress the belts and the clutch,,,also if the mower has been standing un ran all winter it may have "rust" on the engine valves,,running the engine unloaded for a time may knock this off but under load the compreshion is pushed up into the inlet and pops back through the carb,,,try putting into the fule a little "two stroke oil" only 5cc a gall no more! this will lube the velves and carb,,,but sharpen them cutter blades up first,,,or its like trying to eat a half cooked stake with a blunt knife and no teeth? that reminds me? were have my teeth gone?
Jul 31, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Saws Logo
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Stihl Saw Expert? Answer questions, earn points and help others
