It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes... thank u!!! rate me!!
