When I start the min 110-3130nr netbook, HP logo appears and then screen gets blant with a blinking cursor on the left hand upper corner. I have tried F11 recovery but it fils. I have also performed varius hard drive and memory tets by using options available in F2 and F10 but no windows 7(starter ) loads. HP quick web is working fine. Can anyone help. Thank you Puneet Dhawan
SOURCE: When starting my DV4000 - the screen is dark other than a cursor in the left corner.
That error indicates a hard drive problem. You probably have to replace the hard drive.
SOURCE: bios says no ide device found (hard frive missing?)
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
SOURCE: HP Compaq nx 9110 windows xp will not start up
Hi there , have had the same type of display problems with the same model , goes into sleep mode or something similar in the end i downloaded a bois update from hp & installed it , seems
to have helped the problem settle down .
SOURCE: HP PAVILION DV9000 COMPUTER STARTS BOOTING UP AND THEN STOPS.
here is the only solution available on net:
give it a try:
http://amritbera.blogspot.com/2009/09/solved-hp-infinite-restarts.html
enjoy..
SOURCE: HP TX1000 Tablet
click start button in lower left hand corner, then a pop out menu will come up, click control panel, then find mouse, click it, then go to pointer options and click it, see if theres a box checked that says something like (automatically move pointer to the default button in a dialog box). uncheck that box......hope this helps you.......
What error do you get when you do Recovery (F11) ?
