Refrigerators Logo
CHET LABROZZI Posted on Jun 19, 2012
How cold should a Beverage Air Mt 15-54 Cooler get?
JLDrescher
Level 1:
  • Contributor 29 Answers
  • Posted on Aug 27, 2012
JLDrescher
Contributor
Level 1:
Answers
29
Questions
5
Helped
15120
Points
41
Thermostat Set @5, 36 Degrees F
3 Related Answers
Anonymous
  • 110 Answers
  • Posted on Jan 28, 2011
SOURCE: I have a Beverage Air
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Dennis Boxerman
  • 1306 Answers
  • Posted on Nov 28, 2010
SOURCE: my mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Anonymous
  • 331 Answers
  • Posted on Aug 13, 2007
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Mt 23 beverage air cooler hinge is loose and missing a screw
We specialize in cooler gaskets but also sell refrigeration hardware and accessories. If you can provide the model and serial # we can locate pricing and availability for a replacement hinge for your unit. Email me at [email protected] or call us Toll free at 855-288-2259.
Thanks,
Matt
coolergaskets.com
1helpful
Model mt 17-54 will not cool
Go to page 10 of this PDF=> MT Merchandisers (MT Series) If you do not have Adobe Reader Click=> HERE For Customer Service at Beverage-Air=> HERE Go through pg.10 and that should give all answers you need, Good Luck, Sea Breeze
Beverage Air Model MT 45 bottom track warped . needs to be replaced. Where can I find parts for this model. I'm trying to completely restore the unit
We specialize in cooler gaskets but also sell hardware and accessories like shelves, latches, and hinges. If you provide us the model and serial we can locate the OEM shelf you need to replace and provide a price below List price. We'd be more than happy to help.
Email us your unit's info at [email protected] or call us at 855-288-2259
Thanks - Matt
www.coolergaskets.com
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
I have a Bev Air MT-27 cooler for home use. Is it possible to have it rewired so it functions more like a refrigerator so the fan doesn't run 24/7? And if that isn't possible, could I use a timer so that...
On commercial coolers, the fans are designed to run 24/7 to prevent the coils from freezing up. If the unit only runs 4 times a day, it will not maintain proper temps. Domestic units utilize the freezer compartment air to keep the refrigerator section at temp. Totally different set ups. I wouldn't do what you are suggesting with a commercial unit.
My mt 12 cooler doesnt blow cold just warm air
1helpful
3answers
Fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Cooler`s Spare Parts
Coca Cola does not manufacture these coolers. They are manufactured by another company for Coca Cola. Model number MT45 is a "Beverage Air" product.
Some parts for these units can be ordered through a company called "Case Parts" that are on the internet.
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
