SOURCE: Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
SOURCE: Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
SOURCE: How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
SOURCE: epson aculaser c8600 error message E833
my codebook said that in this particular printer service request e833 point to mis-assy ...
i do not know where are you located but in germany this bit cost over 300euro... bit can be exchanged on site by yourself, it is front part of the side feeder assy...
if you find my answer helpful, please do not hesitate to vote4 for me, thanx!
SOURCE: Epson Aculaser C900 photoconductor inserted incorrectly message after changing
I have successfully cleaned an Epson Acculaser C1900 colour laser printer.
Is anyone interested in a totorial (with photos) on doing the job. Before I had white stipes going down the pages. With a screwdriver and vacuum cleaner, it's as good as new.
