2009 Dodge Durango SLT Logo
Posted on Jun 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i hook up an after market stereo in a 1998 dodge durango slt with an infinity sound system w/amp
It has an infinity sound system w/amp?
Adam Scott Roberts
Level 3:
Genius:
  • Dodge Master 1,243 Answers
  • Posted on Jun 20, 2012
Adam Scott Roberts
Dodge Master
Level 3:
Genius:
Answers
1243
Questions
0
Helped
438791
Points
3837
Get an adaptor kit for the stereo wiring. it will plug directly into the factory harness and vertually eliminate cross-wiring.
3 Related Answers
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jul 11, 2009
SOURCE: removed factory stereo and installed after market
Have a look at this link, may help.
http://www.the12volt.com/installbay/stereodetail/710.html
Anonymous
  • 1010 Answers
  • Posted on Jun 19, 2008
SOURCE: 2002 Durango 4 x 4 SLT 4.7L - need to replace broken door speakers
Well its simple, just take your door panel off.
Anonymous
  • 91 Answers
  • Posted on May 06, 2009
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
I have 2004 dodge ram1500 with infinity sound system hooked up kooertron jp816 no sound volume was up
Get rid of the amp. After market radios won't power the factory amp. A bit of wiring to speakers to do. All can be done at the amp plugs.
My 1998 dodge durango slt wont drive past 40 miles an hour
Hello Jeff Winner,
Over the last 20 years ... cars have has a LIMITED OPERATION FEATURE added... When the engine READS something that is not IMMEDIATELY catastrophic... it will allow you to
LIMP home... rather than a complete shut down.
Limp mode:
You SHOULD also have a CHECK ENGINE light... (?)
My best advice is to limp on down to your near-by FREE code reading shop... and have a READER tell you what CODES are registered...
A blocked exhaust system will also seriously SLOW your progress
((soon to stop all-together)).
Hope this helps
Check you exhaust prices BEFORE you go...!!
http://www.rockauto.com/en/catalog/dodge,1998,durango,5.9l+v8,1314473,exhaust 1998 DODGE DURANGO 5 9L V8 Catalytic Converter RockAuto
1998 DODGE DURANGO 5 9L V8 Muffler RockAuto
1helpful
Stereo cuts out
the cd player is old and its giveing out when the pre amp gets hot u should get a pioneer old or new they stand up to anything
1999 dodge grand caravan with The stock Chrysler/Infinity sound system
You can use the amps if your replacement speakers have the same or higher resistance as compared to the original speakers.
1helpful
1998 dodge durango slt compressor keeps on turning off and on
THE IS CAUSED BY THE SYSTEM BEING LOW ON REFRIDGRENT, THIS IS CAUSED BY A LEAK, MOST COMMON CAUSE OF THE LEAK IS THE FRONT SEAL OF THE AC COMPRESSOR.
Stereo not putting out sound
amp may be inside stereo or on rear speakers.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
