See the causes:
During fill only
air gap deformed or crack, the tube crack cause leak,inlet spout crack cause leak.
During drain and spin only
main drain hose, inspect the hose,plastic outer tub can rust or split you must replace the entire outer tub
All the time
check hose for cold and hot water,main tub seal, pump leak replace,outer tub replace.
God bless you
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
