SOURCE: Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Posted on Oct 31, 2007
SOURCE: "replace waste toner box" error
sorry there is no quick solution you need a tech to go into service mode and reset the counter
Posted on Nov 03, 2008
SOURCE: I have a message that
After looking on the net if your printer is under warranty, you should call Kyocera Service Rappresentative or an Authorised Service Centre as Kyocera is not releasing how to empty or clear the waste toner box and if you do you will woid the warranty.
Posted on Dec 02, 2008
SOURCE: Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Posted on Feb 05, 2009
SOURCE: My Magicolor 2300dl printer displays
. Remove Waste Box, Empty box, wipe down w/ dry paper towel
. Turn machine off,. Unplug power cord
. there is a blue rectangular pull knob
.above Rectangular knob @an angle R 2 notches (contain ensors)
. Take an AIR can & hold 6-8 inches & spray N2 ea. sensor
. this should clear any particles that generate a false " Full " Signal
. credit to Nightangel for getting the ball rolling. Thx
Posted on Apr 14, 2009
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Dec 12, 2015 | Kyocera FS-1035MFP
Jul 03, 2014 | Brother WT300CL Waste Toner Box
May 29, 2014 | Konica Minolta Office Equipment & Supplies
Jan 24, 2014 | Brother WT300CL Waste Toner Box
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
Feb 07, 2011 | Sharp MX-2300N Color Copier
Sep 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Oct 18, 2008 | Kyocera Mita FS 3800 Laser Printer
Jul 31, 2008 | Konica Minolta Office Equipment & Supplies
65 people viewed this question
