Cars & Trucks Logo
Posted on Dec 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the horn relay located on a 1978 Chevrolet Blazer K5? I can't find the actual horn either.
  • 2 more comments
  • Anonymous Mar 22, 2009
    cant find horn!
  • Anonymous Apr 26, 2009
    location horn relay 1998 cavalier
  • Anonymous May 09, 2009
    have a 78 c10 and the repair manuals don't give you any clue as to where it is located. wtf i need to talk to those haynes guys
  • Anonymous May 26, 2009
    I think it's by the steering column under dash
Anonymous
Level 2:
  • Expert 27 Answers
  • Posted on Jul 16, 2009
Anonymous
Expert
Level 2:
Answers
27
Questions
7
Helped
13233
Points
108
Horn is under the hood, usually on the firewa, how ever there us a horn relay somewhere unfder the dash on drivers side, pull it and makes sure it makes a clickin sounn if u hook power to it
1helpful
Overheating problems for 1987 chevy K5 Blazer
Is it possible the replacement engine has a water pump that turns the opposite direction from the original ?
The thermostat has to be open to allow flow thru the radiator, have you tried running without a thermostat to check flow ?
1helpful
Where is the horn located on an 1989 Chevy k5 blazer
it is underneith a bracket behind the driver side headlight. :)
1helpful
Where are the horn and headlamp relays for a 1997 chevy blazer? My headlights/highbeams will not turn on.
the horn relay is located behind the glovebox in relay center, the highbeam doesnt have a relay, check the bulbs and also check the highbeam switch located on steering column. hope this helps,
On a 1990 k5 blazer wires does the horn wire go from the steering colum
if the horn press in in the middle of wheel then their is a carbon brush under the steering wheel ,then wire runs into loom from around the steering lock area
3answers
91 Chevy K5 Blazer turn signal flasher
located under the instrument panel to the left of the steering column. The fuse block should be visible from underneath the steering column, near the pedal bracket.
Some models may use an underhood fuse/relay panel
If the panel is not visible, check for a removable compartment door or trim panel which may used on later models to hide the block. This panel is usually located on the left end of the instrument panel.
The convenience center is located just below the instrument panel on the drivers side. It contains individual relays such as the seat belt and ignition key alarm, and flasher.
On newer model vehicles there is an underhood fuse/relay center contains both mini and maxi fuses, as well as some relays.
Replacement The turn signal and hazard flasher units are usually located in the convenience center located just below the instrument panel on the drivers side. Replace the flasher by unplugging the old one and plugging in the new one. Confirm proper flasher operation.
Horn does not work 1998 Chev blazer
It sounds like a problem with your horn relay or fuse...
When looking for relays, the most common spot is in the relay fuse compartment under the hood, either near the battery OR near the firewall2.gif in most instances.
However when troubleshooting2.gif any electrical problem, checking all fuses in both the passenger and engine compartment is crucial before moving on.
Use your owners manual or a Haynes or Chilton manual to determine which fuse is resonsible for which circuit or the information is usually located on the inside of either compartment cover
2answers
Where is the horn on a 1988 k5 blazer
horn is usually in fender at frt,u may have 1 in each fender.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
