Question about Dishwashers
Ultra wash quietguard deluxe
1) power home. c.breaker tripped reset or blown fuse
2) door switch, test for open or defective replace
3)wires for open, break or burn, repair
4)timer or selector swtich, test for open dirty contacts, loose wires, break or burn, or open switch replace.
God bless you
Posted on Jun 20, 2012
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective. The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins. the foil could have moistire damage or the resiistance of the tracks could be too high. Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
Nov 04, 2013 | Electrolux 23 in. ESL624 Built-in...
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Jun 01, 2010 | Dishwashers
Jan 04, 2010 | Kenmore Dishwashers
Dec 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Oct 21, 2009 | Kenmore Dishwashers
Sep 02, 2009 | Kenmore Dishwashers
Jun 25, 2009 | Dishwashers
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
226 people viewed this question
