Question about Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan
Hunter ceiling fan 21871 canopy
How do you remove the canopy from the mounting bracket?
Posted by Gerald Tucker on
4 Related Answers
Anonymous
  • 351 Answers
SOURCE: The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Posted on May 06, 2010
Anonymous
  • 57 Answers
SOURCE: How does the receiver of
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Posted on Jan 23, 2011
sedlewis
SOURCE: I have a Hunter 21871
I'm trying to do just that right now...looking fir a little help with wire color identification. I'll advise you if I have luck.
Posted on May 10, 2011
dchandyman
SOURCE: Trying to remove the Hunter
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Posted on Oct 01, 2011
Where does the receiver go on a model 59016 hunter fan
It goes in the canopy cover at the ceiling. Slide into bracket.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Can't fit remote receiver into canopy of Hampton Bay ceiling fan.
Hang the fan and slip the receiver between the space above the hanging ball on the fan. Hunter remote might not work.
Mar 15, 2013 | Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Fan removal
first- remove the fan blades, next around the canopy there are three screws. remove these and the canopy will drop down. the fan will be hanging on a semi round ball in the mounting bracket. the circuit board should be accessible above the bracket.
Aug 18, 2007 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan Logo
120 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
