HI.THIS needs elaboration.on a general note i am assuming its running but not getting cold.1-check con/unit and should hotish.lack of refrigerant if it is cold and motor running.2-cond/uni cold and motor v/hot and not runnig.suspect motor.con/unit cold motor cold.suspect thermostat the motor.good luck hope it helps.Ali
its not running, no sound, so it doesnt get cold...i plug it in and i get no sound at all. its a compact frige, haiser esrn046bb
hi again.some very compact fridges have a small compressor.if so then again it could be stat or motor.if it is a AMONIA type fridge.it doesnt make any noise at all.opperates by heating the amonia on th huge pipes at the rear.if so itcould be the heater or stat.if both ok then it could be a bloackage in the system.the only shot in the dark is to turn the baby fridge UPSIDE DOWN.TRY ONLY IN AMONI FRIDGES OK? GOOD LUCK.ALI
