SOURCE: I can't control the volume. The TV seems to be
Hi...
If the remote is lost the TV have also a control look at your TV side by side there is any button there you need to reads where is the Volume control
Regards
PCmania
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
SOURCE: menu stuck on and scrolling
did anyone ever get this problem fixed with the gateway menu problem i have the same issue
i cant believe noone has fixed it yet...........i have 2 exact gateway tvs one has a bad image board and the other does the menu thing..i want to know which part to swith to get the menu to stop scrolling all the time
SOURCE: I have a brand new
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
