Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
My sony tv keeps switching off within seconds of my hitting the on button and the standby button keeps blinking (approximately 14 times in total - around 10 if you count after the set turns off - this doesn't seem to fit within the blink-diagnostics). Anyone know what might be causing this or how to fix it? Thanks in advance!
Posted by C Chin on
Prasanna
    Master:
  • 879 Answers
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Posted on Jun 19, 2012
5 Related Answers
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
Paul Buscema
  • 116 Answers
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Posted on Mar 01, 2008
rajanshyam
  • 10 Answers
SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Posted on Aug 31, 2008
Anonymous
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega kv-32fq86b, some times it will switch on and stay on, other times it will switch to standby and keep tha standby light flashing.
Hello
Standby light blinking is a fault indication in Sony sets. You just count the exact number of blinks at one time, after switching on and off the set by its front panel power control switch, NOT BY THE REMOTE CONTROL HANSET. Just inform me the exact number of blinks occur there, after counting it at least four times. It will help me to reach the faulty stage, of sometimes to the exact fault location also. OK.
Dec 20, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wega 36 inch
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
326 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
