Nokia E63 Cell Phone Logo
hemang_21 Posted on Jun 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upside down screen
Nokia e63 phone got display upside down and mirror inverted too
Boston Recycling
Level 2:
  • Expert 229 Answers
  • Posted on Jun 18, 2012
Boston Recycling
Expert
Level 2:
Answers
229
Questions
0
Helped
99583
Points
683
Dial
*#5511# (To bring screen back to normal)
Fred
  • Anonymous Apr 30, 2013
    yet m unable to fix it...after dialing the above thing *#5511#no response from device
Rakhosi
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2015
Rakhosi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
551
Points
I have just tried it now but it can not be reupsided, *#5511# its a code i was offered. can you add more codes please if there is any alternative
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Sep 03, 2009
SOURCE: Cell phone displays mirror image and it's upside down
Hi,maybe the screen not suitable or u have to change the flex cable/ribbon...
Testimonial: "Thanks"
Hi my Nokia e63 screen is upside down,I have tried to punch codes *#5511# up to *#5514# but no response,I have even tried hard reset but to no avail.What else can I try
Make sure it's only upside down only. I mean see whether there are any black stripes, black pixels etc. I think your display contacts needs to be cleaned or get a replacement lcd
1helpful
Nokia e63 requires unlock code
Hi, You can get the unlock code for a Nokia E63 from www.wickedunlock.com/nokia-e63/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA E63
1 - Switch on your Nokia E63 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E63.
3 - Compose #pw+CODE+1#.
4 - The Nokia E63 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E63 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Oct 04, 2012 • Cell Phones
2helpful
Blank white screen on my nokia e63
1.try change screen
2.try full flashing software
3.check lcd ic
Nokia E63, screen has flipped upside down and back to front, have reinstalled software using OVI, but still having same problem, any help would be much appreciated, phone has not been dropped or abused
Did the screen flip like Shaking ? If yes your phone needs some service or the faulty comes from the LCD(display).So if you can open the cover just remove the LCD socket and clean it or you can contact mobile repairing shop.Good luck
On my LG vx8360 the inside display is upside down & mirrored. It just did that one day when I went to read a text. Went to Verizon they were compleatly useless
Hi,what causes upside down display on phones is when the cellphone your using has a flax problem.
A Flex is a thread like object that is located inside the phone. It is connecting both the upper side of the flips and the lower side of the flip phone...
The flex makes the cell phone screen to display...and when the flex is getting damaged, possible signs are upside down display.
To correct the upside down display, you will need to replace the flex inside the cell phone..
For assistance on how to replace the flex, you can go to an expert in phone repair for help..
Hope that helped..
Take care......
2helpful
Inverted display
You can change the display angle in some of the Nokia phones by following codes. Please check if helps you. *#5511# normal screen
*#5512# rotate left
*#5513# upside down
*#5514# rotate right
Please let me know if you find this solution helpful.
Thank you for choosing Fixya
Apr 13, 2010 • Nokia 7610
3helpful
5answers
Yesterday I replace an LCD screen on Nokia E66 but when I turn it on, the view is upside down and mirror also. What is wrong?
my id is [email protected]
change mother bord lcd ic near of paata conactar
you found 3 ic there
change this
my no. 9460108100
Inverted screen of my cellphone
unfortunately, there is no simple answer to this, the only solution is to take apart the phone, and reverse the wiring... which will usually be in a bracket... if it is, you should just be able to flip it, if not, you are gonna need a solder gun to create a hard bypass from the wire to the screen, either way, you have to reverse the wiring and this should fix the problem! hope this helps!
Oct 11, 2009 • Cell Phones
1helpful
3helpful
Camera on phone is inverted...
When you are in the Camera mode, press the Volume button down, that is to set the mirror image, the up button is for upside down or right side up Regards
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
