Question about Activision Call of Duty: Black Ops
Lazer burn my disk works but onlineon nuketown the colors are messed up the only colors in creat a class i cant see my charactor is blured how do i fix
Posted by Mitchell Frith on
  • Mitchell Frith Jun 20, 2012
    should i get a new disk
brandoncap
    New Friend:
    Problem Solver:
  • 10 Answers
If the colors on one particular map are either blurred or not visible, it may be a coding error on your disc. This is easily fixable, as it only needs to be cleaned. If this is a problem for multiple maps, you may need to replace the disc or clean the laser on your XBOX. Either way, the cost of repair is less than $20. First and foremost, though, is to try and play another level and see if that problem is present.
Hope that helps. Good luck!!!
Posted on Jun 27, 2012
The writing is blured and color is messing up
That problem is on the convergence issue..
The problem is usually cause of bad convergence I.C the part # is usually start with letter STK####..and follow by numbers...
Hope it helps..
Dec 07, 2011 | Sony KP-53HS10 TV
Reset my password someone change my password & my secret question so i cant acces it
if you do not have your security question you can not reset the password. its better if you create new one and use aplha numeric password with special charactors in your password. and keep it secret with you only.
Jun 23, 2011 | Yahoo Mail
ASUS DRW 1608 P3S will not load CD Rom computer program disks (it makes clicking sounds then green light goes off and nothing happens). It will play movies but there is no audio, however it will play CD's...
the lazer is not reading try cleaning it with a lazer disc cleaner. but remember most pc burners need replacing after just 2 yrs of work as there lazers burn out fast
hope this helps
Dec 28, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
I am trying to burn using Pioneer DVR-110 DVD RW its starts to burn then after 1 or 2 min it stop and says cannot burn why is that what can i do to fix it please???
You can try and clean the lazer and the 2 chrome rails that the lazer moves along as it reads the disk.To clean the lazer use get some Isopropanol from your local chemist.Use a cotton bud NOT SOAKED with a small amount of Isopropanol and gently clean the glass using a circular motion and and polish with a clean and dry cotton bud.To clean the rails use special fine machine oil. Do not use WD40 as it contains water.Hope this helps you.
Regards Bill
May 08, 2010 | Pioneer DVR-110D DVD RW Dual Layer Burner
My sony KP-46WT510 the color in three corners is blured and the picture is bowed.
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Sony or look for your light engine online.God bless you and your house!
Nov 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The game says clean and i do a lot of times andit
http://www.xbox-scene.com/articles/philipspot.php
maybe a lazer problem, it cant read the disk, the disk might be clean but the lazer is not.
Nov 08, 2009 | EA Sports Madden NFL 08 for Xbox
Cd rom drive won't burn audio cd's
Try using a lazer cleaner in your cd drive,other wise the cd disk might be faulty,try another disk.
Dec 20, 2008 | Gateway GT5220 PC Desktop
Won't play recorded cd's
Try this link. It offers resistor changes which are designed to fix your problem of inability to play any CD R. on that model Nakamichi. jacknz0 http://home.cogeco.ca/~niteowl/Nak_MF51.jpg
Dec 31, 2007 | Nakamichi MF-51 5-Disc CD Changer
Activision Call of Duty: Black Ops Logo
138 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
