Question about Kenmore Dishwashers
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
On the control panel the normal wash cycle green light is on and the heated dry option green light is on the start resume green light is flashing. I have already disconnected the power supply overnight. I have tried to reset by pushing the normal wash heated dry buttons but nothing happens.
Posted by TOM CARTER on
Krzys Twardzik
I was similar isuee, I had to call for expert https://appliancerepairexpert.ca
Posted on Jul 23, 2019
ernesto cuadra
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
See your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Kenmore Ultra Wash Model 665.1388 problem the norm - 6_19_2012_3_24_54_am.gif
Posted on Jun 19, 2012
5 Related Answers
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
Mark Egan
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
Anonymous
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
RED92JEEPER
J. KUYKENDALL
  • 51 Answers
SOURCE: Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
Posted on Sep 27, 2009
Anonymous
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 09, 2015 | Kenmore Dishwashers
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
Jul 20, 2014 | Kenmore Dishwasher With Ultra Wash And...
THE FOLLOWING BUTTONS WERE DEPRESSED.......NORMAL WASH, HEATED DRY AND LOCK ON......ALL THESE BUTTONS HAVE A STEADY LITE.....THE START/RESUME BUTTON LITE IS FLASHING. IHAVE HELD THE START/RESUME BUTTON...
Hi
Press and hold the NORMAL WASH-HEATED DRY button simultaneously & repeat this sequence for 5 times...this will reset the control. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
Lock On
To turn on the Lock
flashes 3 times.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
855 people viewed this question
Top Kenmore Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
