SOURCE: nikon coolpix 5700 flash isn't
I can help, I just need a few more details...
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
SOURCE: CAN I USE THE NIKON
Sorry, no. the L110 is designed to store images and videos to memory, not to stream live video to another device.
SOURCE: Nikon Coolpix L110. Less than
Are you using good quality batteries? Cheap supermarket batteries (usually zinc carbon) tend to be weaker than quality alkaline batteries. Look for alkaline batteries with the code "mn1500" somewhere on either the battery or the packet. Also, rechargeable batteries can vary between brand in that some hold less charge for less time than others. So look for the code "2000" or "2500" on the pack if you want to use rechargeables. Many cameras use only 2 AA batteries and it takes a lot of power just to start them (charging the flash and extending the lens etc.) and need a good battery for them to work.
If this doesn't solve the problem (I think it should) then you may want to return the camera and have it replaced under warranty.
Hope this helps.
