SOURCE: factory settings
There's a couple of things you can do:
Press the F2 key to enter the BOIS setup and reset those defaults
and/or
Use the driver disc. It writes a complete image on the hard drive with all the drivers.
SOURCE: how to restore toshiba satellite factory settings
pls be more specific....
are you planing to format you machine....
what factory settings.....
SOURCE: how do I reset a Toshiba Satellite Laptop to its
you use the backup disk or purchase a windows installation disk please rate if i helped
SOURCE: how do i restore my toshiba p300-172 back to
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
Testimonial: "tnx i just remembered it never came with a recovery cd but it did come with toshiba recovery disc creator, might give it a try wen i get some cd's."
SOURCE: how do i resore my toshiba satellite pro L450D-12X
Format the drive, then install an operating system such as xp, or
windows 7 .... it should install most of the correct drivers. If you have the original disks that came with the computer, use those.You may
have to go to the manufactures website to find the exact drivers for the
video and sound cards., but that should pretty much return it to
factory settings. If you are really picky and have the bucks, you can
contact TOSHIBA for the original disks.
PLEASE CLICK ON SOME THUMBS UP FOR THE ADVICE!!!
