Question about Whirlpool Refrigerators
Whirlpool WBM39MW alarm when door opened
When door of fridge or freezer is opened, led flashes, alarm sounds and fan goes on off on off. Everything seems to work just fine, just this crazy annoying alarm going off every time fridge is opened. Any ideas? ty in advance.
Posted by Glen G on
Mick
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Where is the temp sensor located?
Posted on Nov 09, 2017
  • Mick Nov 09, 2017
Chris Jowsey
    Champion:
  • 208 Answers
Just had one of these with the blinking light, fan pulsating and no cooling. The fault is the power supply section in the control module at the back. It is a 2uF 400VAC capacitor going open circuit. make sure you replace this capacitor with something equal or better rated - it is critical
Posted on Mar 17, 2013
5 Related Answers
Anonymous
SOURCE: whirlpool frost free tropical, seems
Check the sensor in the refridgerator... on the right,,
Posted on Sep 22, 2008
Anonymous
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
Anonymous
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
Anonymous
SOURCE: LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
If your fridge is left open over night and it wasnt closed till morning and the alarm light does stop flashing when it is closed what does that mean?
Hi and welcome to FixYa, I am Kelly.
FYI... The door alarm will sound anytime the door is left open for more than 4 minutes.
Per your post... What it means your refrigerator is working normally.
However... there is the possibility of having excess ice build up on the evaporator coils from the door being open all night. If the freezer section starts warming up due to poor airflow you may have to do a manual defrost. You would first notice the lack of ice production or soft ice cream if there were air flow problems due to excess ice on the evaporator coils.
To do a manual defrost all you do is:
1. Unplug the unit
2. Remove freezer contents
3. Use a fan directed at the freezer compartment for just over 2 hours (makes a water mess)
4. Reload the freezer
5. Plug in the refrigerator
Everything should be back to normal in just over 4 hours except ice production that can take up to 8 hours.
Thanks for choosing FixYa,
Kelly
Nov 21, 2010 | Whirlpool Refrigerators
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool fridge freezer ARC 4030?
Look to have the control module repaired / replaced.
Hope this helps
Dec 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
670 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
