I enter the code for a6 and phono comes up on display
I got new battery when i entered the radio code i might have hit wrong buttons to log it in now phono keeps coming up in radio display and still not working
Press the p.scan and RBDS buttons at the same time, when done correctly the display should change from safe to 1000, then use the 1234 buttons under the display to enter the code.
You may have the wrong code it should be a 4 digit code.
it depends on year of car and make of RADIOHERE IS THE SETTINGS FOR A 2002 AUDI A6 Quattro V6 2.7L Turbo (APB) engine code
For the Audi Concert Radio
YOU STILL NEED YOUR RADIO CODE TO ENTER THIS!!!!!!!!!!!! tell me if this work for you
Entering Anti-theft Code
The following is the procedure to re-activate the radio if the display
shows "SAFE". It is important that the procedure be followed in the
correct order.
1. Turn on radio. The radio display shows "SAFE".
2. Press the FM2 and RDS buttons simultaneously and hold until "1000"
shows on the display. Release the buttons. Do NOT press these buttons
again, otherwise the radio will consider "1000" to be the code.
3. Use Preset buttons 1 ... 4 to enter the four-digit code number
from your radio card. Preset button 1 corresponds to the first digit,
Preset button 2 corresponds to the second digit, etc. Each press of the
button increments the number by 1.
4. Once the code shown on the display is correct, press the FM2 and
RDS buttons simultaneously and hold until the word "SAFE" appears in the
display, then release the buttons.
5. The radio should unlock and be usable shortly afterwards.
6. If an incorrect code is entered, the word "SAFE" appears, first
flashing and then continuously. You can repeat the above steps to unlock
the radio once more, the number of attempts will be shown in the
display. If an incorrect code is entered again, you radio will be locked
for about one hour. After one hour - the radio must stay on and the key
must remain in the ignition lock - if the display goes out, the you can
repeat the above procedure to unlock again. The cycle - two attempts,
one hour lock-up - still applies.
7. If you lose your radio code, contact your Audi dealer.
Note: Some European market Concert radios have a TP button instead of
the FM2 button, so the description above with those units would require
pressing the TP and the RDS buttons simultaneously.
urn on radio - the word SAFE will appear in the display. Press th
P.SCAN and RBDS buttons simultaneously and hold them down until "1000"
lights up in the display.Release buttons.Do not, under no circumtances,
continue holding them down or press them once again. This will cause
the radio to consider the number 1000 to be the input code.Use station
buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use
the button 1 to enter the first number 2 for the second number 3 for
the third number and 4 for the last number.Once you have entered the
code and it shows on the display,press the P.SCAN and RBDS buttons down
again simultaneously and hold them down until the word SAFE appears in
the display.Release buttons. Soon afterwards a frequency will be
displayed.
Did you disconnect the battery or run it down? This message means you must enter the correct code. If you do not have the code contact your Audi dealer. I'm not sure which model you have but these are the instructions for Symphony 1. I'm not sure if this also applies to Symphony 2 (which has a built in single slot 6 CD changer)
Switch on - display shows SAFE as you indicate. Press and hold TP and RDS buttons at same time until 1000 appears. Release buttons (dont touch again or 1000 will be entered as the code). Using station select buttons 1 to 4 enter code. Use button 1 to select first digit of security code, button 2 for second digit etc (buttons 5 and 6 cannot be used). So, say the code is 5238, you'd press '1' five times, '2' twice, '3' three times and button '4' eight times. Once code is entered press TP and RDS buttons together and holde until SAFE appears Release buttons and a radio frequency will appear in the display.
If you accidently enter the wrong code the word SAFE will start flashing. You get ONE more chance to go through this procedure and enter the correct code. There is a more complicated procedure to go through after this with one hour time delays between attempts.Curtorsey Audi Owner's Club:
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
You must get the 4 digit security code and enter it into the radio by pressing the AM and FM2 buttons at the same time. Then enter code via the preset buttons. Press button #1 until you get the first digit of the code then press button #2 until you get the 2nd digit and so on for the 3rd and 4th digits. when code is on the display press the AM and FM2 buttons again and radio should come back on. if it reads safe you have the wrong code #. You can get the code from a dealer for a small fee. They need to remove the radio to get a serial # on the radio chassis.
I have a Saab 900 -97 with a similar problem. I just solved it yesterday on my car. Hold the Band button in for like 10-15 sec when you see "Code In", It clears the error log in the radio. If it doen´t work, enter a wrong code so the code hangs on the display and then press the band button to clear the error log. It worked on my car, good luck!
Entering anti-theft code
The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
Press the P.Scan and RBDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
Once the code shown on the display is correct, press the P.Scan and RBDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
