Question about OKI C Office Equipment & Supplies
SOURCE: Oki C5200n 002: Fatal Error
We have to change firewall settings in our Fios router. I just don't know which ports or udp to open.
Posted on Jan 08, 2008
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Posted on Dec 08, 2008
SOURCE: Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Posted on Mar 24, 2009
Apr 13, 2018 | OKI Office Equipment & Supplies
Jun 20, 2016 | OKI C Office Equipment & Supplies
Jun 02, 2014 | OKI C7300 Led Printer
Apr 26, 2010 | OKI C5650n LED Laser Printer
Jun 19, 2009 | OKI C5150n Led Printer
Apr 16, 2009 | OKI C5200n Laser Printer
Mar 15, 2009 | OKI C5100n Laser Printer
Jan 07, 2009 | OKI C9600hdn Laser Printer
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Mar 07, 2008 | OKI C5300n Led Printer
351 people viewed this question
