L cleared all my other bluetooths
SOURCE: blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
SOURCE: I cannot remember how to pair BlueAnt bluetooth to new devices
You will need to set the Z9 into pairing mode before your iPhone will find it.
The manual for the z9 is here
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair.
SOURCE: Forgot how to put my Blueant in pairing mode. the
Turn it off, then when you turn it back on keep the power button (the green one) down until the blue light starts flashing red and blue.
SOURCE: What is the default password please to pair up a Blueant BTSVBC3?
Try with 0000 (four zero) or 00000 (five zero) or 1234 or 12345.
Good Luck!!!!!
