Manual for sylvania tv model SSL2006 - Televison & Video
Posted by roy barber on
SD Tech
    Top Expert:
  • 14,553 Answers
Your best bet would be to contact Philips who makes this or Google the model number with "manual" to try to locate one.
Posted on Jun 17, 2012
4 Related Answers
barbu51
Jacques Marin
  • 566 Answers
SOURCE: Sylvania SSL2006 dead, won't turn on. fuse is ok,
Hi larry
Since you know electronics that will make the explanation simpler;
On your tv model there is a very common problem that you may want to look at;
There is a small board on the right hand side(backlight inverter board),
Look for a shorted D309 , it is a 9.1volts 1watt zener diode.
As i said it is a common problem for your model.
But there is also the power supply;
All lcd tv`s nowadays it seems end up with bad capacitors in the power supply,
You can recognize them by their rounded tops and you`ll find them at the output of the power supply along the 5/12 and 24volts line.
But especially on the 5 volts line.
If your not sure which ones then replace them all (there might be 6 or 7 of them) it won`t hurt and eventually they will go anyway.
Hope this help good luck
Posted on Jan 08, 2010
Anonymous
SOURCE: sylvania SSL2006 lcd tv
Did anyone figure out a solution or did you get rid of the TV?
Posted on Oct 03, 2008
Anonymous
SOURCE: ssl2006 sylvania TV goes dim and turns off within 5 seconds when turned on
POWER SUPPLY SHUTTING DOWN
Posted on Dec 15, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: ssl2006 sylvania tv shuts off after a few minutes.
If you always leave it plugged into the wall, it was running 24/7 even if you never turn it on!
It may have power supply problem (bad caps, cold solder joints, etc.) and that will be the first palce to look.
Please read my guide so you will undet stand how TV works.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Posted on Nov 25, 2010
SSL2006 TV Q601
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 23, 2014 | Sylvania Televison & Video
Sylvania ssl2006
How do you know it is the fuse? Did you take it apart and look at the power board? If so, what is the model number?
Aug 12, 2013 | Televison & Video
Model SSL2006 will not accept TV (cable) channels above 13.
You must be sure you are in connection with the menu. Read the menu and find [video source] antenna/cable. Be sure you are in "cable" source. And then program your TV for channel search! Try this, and thanks for asking!
Oct 06, 2010 | Sylvania Televison & Video
Hi larry
Jan 08, 2010 | Sylvania Televison & Video
Ssl2006
I looked at the manual. YES YOU NEED A CONVERTER. This unit does not have a digital tuner. It is a fairly nice, low-resolution (not high-def) TV with an analog tuner..
Dec 30, 2008 | F5 Networking (F5-ADD-BIG-SSL5000)...
Sylvania SSL2006 lcd tv
Feb 19, 2008 | Televison & Video
Dead t v
Good Luck! My SSL2006 tv would cuts off when turned on. Under warranty, the local auth. repair shop tried unsuccessfully to replace parts to fix it. In addition, the repair shop told me it was difficult getting thru to parts support. Either the wrong parts were sent, the right part didn?t work, or additional authorization was required to repair TV. On many occasions I made calls to Sylvania, on the repair shops urging, to find out the status on its repair parts to help get the right parts sent. The set was in an auth repair shop from Feb.-Aug. The shop couldn't fix it. It was sent to Sylvania's repair center in CA, August 18th. WHEN WILL I GET MY TV BACK? I want a new TV!! I have been without this TV for over 6 mos.! I'm very upset with customer service and its repair centers and will never buy nor will I recommend purchasing a Sylvania product.
Sep 02, 2007 | Televison & Video
Black screen after 1-2 minutes.
Hi, I just fixed one I bought on eBay with the same problem. My problem was caused by the screen backlight inverter. Fortunately I had one from another TV I bought last year on eBay. The repair only took about 15 minutes. Your best bet is to contact Funai Corp. and really complain even if it is out of warranty. They make Emerson, Funai, Symphonic and Sylvania and all the parts inside are the same (from the same years). If that don't work look on eBay for one with a broken screen or some other damage, call your local dealer and see if they have the inverter from a broken TV or ask around. We have a freecycle group in Michigan that recycles things rather than throw them in landfills you may have one in your state too !
Good Luck,
Jul 15, 2007 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
