Question about Sirius Satellite Radio XACT XTR2 Satellite Radio Receiver
Xact XTR2 will not turn on
The plug to the cig lighter lights up and shows that it is working but the reciever will not turn on.
Posted by kzweber79 on
TSS Radio
    New Friend:
  • 62 Answers
Its likely that the unit itself is bad. Do you have another dock or boombox to plug it in and trouble shoot with? If it doesn't power up in multiple sources it could be dead. Either way, TSS Radio can help:
tss-radio.com
Posted on Jun 29, 2012
Have 93 s10 and I put CIG lighter back in and the radio dome light glove box light and lighter quit working
Check the fuse. I have seen a penny fall into the hole where the cig. lighter plugs into.
Apr 07, 2015 | Cars & Trucks
1989 Seville fuse for cig lighter
did you measure the voltage at the lighter center pin
moreover its prob the lighter plug in coil thats gubbed
not the supply
try buying a coffee etc heater and plug it into the cig lighter
does it work well then its the coil
look inside the fuse cover panel it will show you what fuses do what,,,
Mar 26, 2015 | 1989 Cadillac Seville
Abs light
Sounds like you shorted out the cig lighter which can also power other circuits. Have you checked the cig lighter fuse ?
Jul 01, 2013 | 1992 Buick LeSabre
2007 toyota corolla no lights, wont start
What did you plug in? I had a similar issue when I plugged in a high amp tire pump. It kept blowing fuses because the pump itself had a short. Be wary of using stuff like that in the cig lighter. I switched to a hand held pump. How was the computer found to be defective? I wonder if the cig issue shorted the computer?
Jul 15, 2012 | 2007 Toyota Corolla
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Satellite radio
I have several 'ghettoblasters' that fit this unit if interested --- Frank
Jul 14, 2008 | Xact Communication XTR1 SIRIUS Radio...
Sirius Satellite Radio XACT XTR2 Satellite Radio Receiver Logo
176 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
