Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Turned on id-1 now it wont change back
About the only way you could have done that is by entering the Tech menu--that is why I will not offer that information for people here as it makes matters worse---get a Panasonic tech to undo the damage.
Posted on Jun 17, 2012
SOURCE: PT-40LC12 fuse problem
Sent me the serial number, and I can check for any re-call ...
my e-mail is <[email protected]>
Posted on May 22, 2008
SOURCE: lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Posted on May 28, 2008
SOURCE: panasonic pt-40lc12
Panasonic has a part number for the fuse: LSJA0411-1
Posted on Jul 23, 2008
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Posted on Jan 20, 2010
Testimonial: "Thank you so much for your help. Worked like a charm!"
SOURCE: hello, I have a Panasonic
your lamp has gone out. replacement can be ordered online for about $175.
easy to install, plug and play.
Posted on Apr 14, 2011
Apr 14, 2011 | Panasonic PT-40LC12 40" Rear Projection...
Nov 03, 2010 | Panasonic PT-40LC12 40 in. LCD Television
Jan 20, 2010 | Panasonic PT-40LC12 40" Rear Projection...
Dec 08, 2009 | Panasonic PT-40LC12 40 in. LCD Television
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Mar 19, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Nov 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Oct 24, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Aug 01, 2017 | Panasonic PT-40LC12 40" Rear Projection...
