The AH59-02330A remote came with the Samsung HW-D550 sound bar. It is not a universal remote control and will only control Samsung TVs. (The remote may also work with other Samsung audio devices, including the HW-DW551.) Samsung has the manual on the HW-D550 support page: https://www.samsung.com/us/support/owners/product/2011-2-1-channel-soundbar-hw-d550-hw-d551 . See page 10 of the manual for the limits of the remote. The current link to the manual is https://downloadcenter.samsung.com/content/UM/201102/20110201172514949/HW-D550-D551-USA-ENG-IB_cms_0126.pdf .
Since the HW-D550 was manufactured in 2011, the AH59-02330A remote probably doesn't work with all Samsung TVs built after that date. Manufacturers change codes fairly often. This means that newer universal remotes can control older devices. The reverse is never guaranteed.
Try setting up speakers through your TV. (I suppose your Tv is wifi in to tv) Tap menu on tv remote. Go to network. Tap wifi, then follow TV's direction.
The video in the PVR is not in DVD or Blu ray format. You'll need software to convert the video format on the PVR to DVD first. there are several converters that will do that. Google video to dvd converters.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
code URC HW error: HW usually stands for hardware which means some part of the electronics has failed. Without a model number I can't look up the code "URC" but I'd suggest you do a search on the web for "Motorola model ##### error codes"
Sorry but you cannot do this with this tv.. You need hdmi 1.4 support and you only have 1.3 the only way i have heard of it being done is through the headphone socket to a 3.5 jack to the aux socket on the soundbar.... johnB
Look on the back of your TV for an HDMI port that has "ARC" on it, connect that to the HDMI Out on the subwoofer. Make sure that your HDMI cable supports ARC. That is the only connection you should need to the subwoofer, remove everything else. Other option is an optical cable between the TV and the Subwoofer.
I just discovered this after fooling around with it for the past couple of days!
