Computers & Internet Logo
Windows Update error code 80070103
Tried several times to install update for Bluetooth & every time getting the error code as above
Posted by Pierre-Henri... on
madison smith
    Novelist:
    Habit-Forming:
  • 88 Answers
Basically Windows Update Error 80070103 happens after you conceive to update drivers with Windows Update, however the drivers are already put into your laptop. Instead, an equivalent error will happen if you are attempting to put in a driver that contains a low compatibility rating together with your machine. This windows update 80070103 error may appear as different message in your Windows Os operating systems 7, 8, 8.1 and 10 stating any of the following:
  • Windows could not search for new updates. An error occurred while checking for new updates for your computer
  • Error(s) found: Code 80070103 Windows Update encountered an unknown error
  • Windows Update ran into a Problem.
Causes Of Windows Update Error 80070103
Here are several possible reasons why Windows update error 80070103 can occur:-
  • You are trying to install an incompatible driver over one that already exists for a particular device.
  • Another reason you may encounter this error is that there is a problem with Windows Update.
In each case, there'll be some manual intervention needed from you to proceed with the task and restore your system. Here are some suggested ways you ought to attempt to resolve the matter on your own.
Method 1: Update device drivers using Windows Update to fix Error code 80070103
Method 2: Manually update the drivers
Method 3: Hide Update
Method 4: Reinstall the device drivers
Method 5: Run the Windows Update Troubleshooter
Hopefully, you'll be able to fix the bug on your own with the assistance of the on top of strategies.
Posted on Aug 25, 2020
Mike walsan
    Sergeant:
  • Computers & ... Expert
  • 161 Answers
Microsoft Windows is the worlds most used operating system, Some of the windows users may face the windows error code 80070103 while updating the windows, If your one of them then this article will help you understand how you can solve it? and why you're facing this error. So without any further delay lets get started...
Why you're facing this error?
Error Code 80070103 is pop up when your system is trying to install the drivers which are already installed on your pc. Or sometimes the drivers on your pc is corrupted because of the virus and malware and your system try to reinstall in this condition Error Code 80070103 will pop up. Now let's understand how you can solve this.
How to solve it?
Error Code 80070103 is a common error you need to worry about it, It will solve if you follow the below steps correctly,
Here I am going to tell you two different method to solve it, For is to manually update your device drivers and second is to Rename software distribution folder, Both of the methods are able to solve, Try both methods one by one, I will assure you that your error will be solved, Lets start with method first of manually updating drivers.
The best solution to this error is to manually update the device drivers which system unable to update. so let's understand how you can update it manually.
  1. first, go to setting
  2. Then click on update and security
  3. On the left-hand side, you get an option "Windows update" click on it
  4. Now click on View installed update history.
  5. Look for the windows update which Fails to install
  6. Now select the derives and right click on it, Here you get the option to update it.
After updating the drivers restart your PC and check for the error, If you're still facing to error then move to the next method.
To solve the error by this method just follow the below process
First of all, go to the start menu and search for CMD, Open it.
Now type the following CMD one by one in it
  1. net stop wuauserv
  2. net stop cryptSvc
  3. net stop bits
  4. net stop msiserver
After doing this now enter the following CMD one by one to rename the software distrubution folder
  1. ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
  2. ren C:\Windows\System32\catroot2 catroot2.old
Now after that enter the follow CMD
  1. net start wuauserv
  2. net start cryptSvc
  3. net start bits
  4. net start msiserver
After complecting this restart your pc and check for the error, If still, you're facing this error then move the method third.
If you understand both the above method, If after following the above method you're still facing this error lets me know in the comment section, We will help you to solve it.
Call On Our Technical Support Phone Number for fix windows error code 80070103 Errorcode Expert
USA +1 (800) 848-5295 Right Now to Get Instant Help
Posted on Feb 13, 2019
LilyHart
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Simple SFC scan method for common file system issues to fix windows update error:-
The system file scanning process is very simple to try while fixing issues with Windows issues. Just follow these steps.
Open command prompt in admin mode, to do this Type CMD in windows start menu search and right click on CMD application to get through Run as admin option.cmd window
In the command prompt window, type SFC/SCANNOW and press enter
The scanning process takes some time to return results.
If you are still facing the issue, visit theis website
https://www.errorsolutions.tech/error/windows-update-error-code-80070103/
Posted on Apr 27, 2018
Mrityunjay Naskar
    Sergeant:
  • 267 Answers
This windows update error code means you already have the latest drivers installed onto your computer and you don't really need to upgrade it.
To know more, follow this link: Windows Update error code 80070103
or you can also visit: Update error Code 80070103
Hope this helps, Mrityunjay.
Posted on Jun 17, 2012
5 Related Answers
Anonymous
  • 65 Answers
SOURCE: I can't install XP on Thinkpad A20P #2629
im sorry to say this laptop is just not fast enuf to run windows XP you best bet for this would be to run windows 98 or a distro of linux that fits your needs  there are no bios updates at this time that will allow you to install XP on this system. sorry
Posted on Mar 27, 2009
Anonymous
  • 413 Answers
SOURCE: how i can install xp sp2?
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from www.download .com
Posted on May 09, 2009
Anonymous
SOURCE: I have only just today received my brand new HP
I had the exact same problem.
As some nice fellow pointed out at HP forum, HP as a downloadable package that should fix this problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02219204&cc=nl&lc=en&dlc=en&product=4213233
Kinda sucks thought that thoses folks at HP Support are not even aware of it...
Posted on Jul 30, 2010
Anonymous
SOURCE: i have a r40 ibm laptop problem is date &
just reverse the negative and the positive on the bios battery have fun ...youre welcome. no ac adapter needed you can keep it on your laptop battery and not worry about the cmos battery dying
Posted on Jul 02, 2011
Anonymous
  • 102 Answers
SOURCE: My computer security updates fails
Check this answer at answers.microsoft... it may be as simple as turning off your antivirus while installing these update. You may also try the installation in Safe-mode.
Posted on Aug 09, 2011
1helpful
2answers
How To Fix Windows Error Code 80070103?
google it , go to microsoft answers forum, all answers will be there
Windows update failed
You version is no longer supported, time to upgrade
2answers
Hp mini 1000 cannot receive files using bluetooth from mobile phones
When a notebook is configured to automatically download and installupdates from Microsoft´s Windows Update, the Bluetooth hardware may notfunction after certain updates. The Windows Update function may installMicrosoft versions of the Bluetooth software and drivers that areincompatible with HP products.
Method 1: Re-install HP Bluetooth software Do the following steps to uninstall the Microsoft software and re-install the Bluetooth by HP software.
  1. Click Start, Control Panel, then Add or Remove Programs.
  2. From the list, Click Remove next to the Microsoft Bluetooth Drivers.
  3. Once the drivers have been removed, click Start, Help and Support then Update Software & Drivers.
  4. When prompted, click System Health Check. When presented with a listing of Updates for Driver, Bios and Software, select HP Bluetooth software.
  5. Follow the prompts to install the software.
Method 2: Review Windows updates before installation Do the following steps to prevent Windows from automatically installing incompatible Bluetooth drivers in the future.
  1. Open the Windows Update site and under the Automatic Update section click Pick a time to install updates.
  2. On the Automatic Updates window, click More Options.
  3. Select the Download updates for me, but let me choose when to install them option and click OK to accept the change.
  4. In the future, when presented with a list of updates, do not install any Windows Bluetooth updates.
4answers
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
1helpful
2answers
Problem when i installed in windows vista
There is still plenty of hardware issues with Vista, so go to the cam or Windows web site for related issues and see if there is a patch. Make sure the cam is also set up correctly and use windows live if your'e still using MSN. You can also try installing Windows XP drivers as they are sometimes accepted and work.
Marvin
Marvin
