old post but im flooding geo posts
so other can search and find answers for this rare old car,
there is no switch
only a relay , actually 2 relays.
one is fuel realy in green socket below ECU and
other is ecu mAIN, next to above in black sockete
if either fails, car will not start
they are same p/n so can be swapped.
if CEL glows in cluster key on, main is ok
are FI and IG coil fues good at left top knee?
no start, just for this car alone.
http://www.fixkick.com/nostart.htmlHERE
http://www.fixkick.com/INJECTORS/PUMP/Fuel-Pump-Relay1w.jpgIF THE PINK WIRE GOES TO 11 TO 12 VDC CRANIING
ITS NOT THE RELAY
IF NOT NEAR 11V, THE ECU IS BAD OR IT HAS NO POWER.
FUSES BAD TOPS LIST
THE FI FUSE MUST BE GOOD
IF THE IG COIL FUSES IS BAD THE ECU IS DEAD, OFF LINE.
