Question about Video Game Consoles & Games
Help...Lost the power adaptor for my Lumisource Boomchair SVC. What are the power specs?
Lost the power adaptor for my Lumisource Boomchair SVC. Does anybody have one of these gaming chairs that can tell me what their power supply housing says on it? Maybe take a picture of yours and post it for me. I would really appreciate it. Thanks.
Posted by Indy12345 on
Steve
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
No need to worry about positive or negative - it's 12 V AC, 2.5 A. If you unscrew the 6 screws in the plate with all the connectors on it, and gently pry it out, you'll see that the black cord with the power connector on it just connects to two wires, one yellow and one white, that run down inside to the power amp board. You can just disconnect the black cord, and wire in whatever cord works with the power adapter you find, or just cut the power connector off of the black cord, and replace that with the appropriate jack that fits the adapter you find.. You can use a DC power supply of at least 14 V at 3 A - but don't go much over 16V. A lot of laptop power bricks will do this, and they readily available. Since the wires go to a bridge rectifier, it doesn't matter which wire you connect + or - to.
Digi-Key part number HM1577-ND is available for immediate shipment at $20.57. It's a plug-in wall transformer with two screw terminals. 12v AC, 2.5A 40W.
Made by Hammond - a high-quality part. This would get you up and running in 10 minutes or less.
Posted on Oct 12, 2017
sunnedays
    New Friend:
  • 4 Answers
I need one too. I found the owners manual on-line and it says the AC/DC Adapter we need is 12volts and 2500ma (2.5amp). I wrote to the company to see if one is available. If not, I may just try to find one that matches the voltage and amperage, cut off that odd male end and wire it directly. the only issue will be finding the positive and negative.
Posted on Nov 14, 2015
Nick Hirdes
    New Friend:
    Welcome Back:
I FOUND THE SOLUTION. Take a power brick from an Xbox 360 slim and cut and strip the ends of both the cables on the chair and the small cable on the power brick and solder the black and red wires to the corresponding wires on the chair. There will be two wires left over on the brick a green and a white one you will have to solder in a switch to these wires to turn the brick on so it will put out the full 12 volts that the chair needs.
Posted on Mar 19, 2018
ccaa
    New Friend:
I lost mine the same month I got it as a kid, having this answered would help me too, since its merely a floor chair and none of the electronics are useful since I don't have any idea what kind of adapter I aught to search for as a replacement. The online manual isnt helpful, so if anyone can figure out what in the world type of hookup the receptacle cord is, then i can begin trying to figure out what type of 12v adapter I need to find. The receptacle cord has a chamfered bar prong and a tiny tubular prong, and I haven't the slightest clue what kind of power supply block accepts those shapes.
Posted on Jan 08, 2015
  • jerzram Oct 30, 2020
    Just cut off the plug and wire in any 12 volt power adapter with at least 2 amps, thats what I did I picked up a lumisource boom chair svc cheap with no power adapter and wound up wiring in a 12 volt 2.5 amp laptop power adapter. Works great
What type of powersupply
12V 1.2A AC Adaptor Power Supply Charger
Dec 29, 2012 | Pyramat Sound Rocker Gaming Chair
Lost my boomchair svc plug adapter
Look on a website for a new one/ go to the manufacturer's website. You should be able to buy another one.
Mar 17, 2012 | Office Equipment & Supplies
We just bought a boompod from a garage sale and it came with no cords. What do I need to buy to hook it up to our x box and ps2? Does it hook up to the tv or the game system? Is there some where I can...
Boompods are made by LumiSource, the maker of Boomchairs. How to hook up your chair to most devices are on the www.boomchair.com website. The Boompod is made to play primarily hand held games, like PSP, Nintendo DX, etc. But you just need the audio cords with the red and white RCA jacks on both ends to hook up to your TV's audio output. Go to a Radio Shack and they'll hook you up.
Aug 01, 2011 | Video Game Consoles & Games
What is the voltage on the vibration moters in a boomchair svc
i found 2 boomchairs lumisource SVC i will make tst expect 12 volts 2 Amps
Jul 24, 2011 | Electronics - Others
Just bought a boomchair SVC and the rumble on it will not turn off. Any ideas?
I have the same problem, and after cutting the bottom open to get to the mainboard, I discovered that playing with the 4 pin (2 brown, 2 white) connector between the two boards on the main board seems to calm it, and stop it from vibrating.. I just can't get it to stay off. Bump for help!
Nov 23, 2009 | Pyramat Sound Rocker Gaming Chair
Help
That is the specs of the ac adaptor that the X Rocker Chair uses to power the speakers on.
It uses a 10 Volt Ac Adaptor that runs off of 1.2 amps.
May 28, 2009 | Pyramat Sound Rocker Gaming Chair
Video Game Consoles & Games Logo
2,031 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
