Campbell Hausfeld PW2102 Gas Pressure Washer Logo
Posted on Jun 16, 2012
PW2200V4LE engine oil type - Campbell Hausfeld PW2102 Gas Pressure Washer
I have seen conflicting info about the correct oil to use for the ‘09 Civic Hybrid. Could you answer, and direct me to this answer on the Honda site? Thanks much!
2009 Honda Civic
L4-1.3L Hybrid
Fluid Types
  • Vehicle
  • Engine, Cooling and Exhaust
  • Engine
  • Engine Lubrication
  • Engine Oil
  • Specifications
  • Fluid Types
FLUID TYPES
Engine Oil
Type .................... API Premium Grade 0W-20 Detergent Oil
A 5W-20 oil may be used if 0W-20 is not available.
You may use a synthetic oil if it meets the same requirements given for a conventional motor oil: it displays the API certification seal, and is the proper wei
1helpful
ST175G, 2 cycle engine, I lost the manual and I cant remember the percentage of the mixing oil and gas. It has been a few years since I did it. Please help. Thank you, Roger
the type of oil to use is 2 stroke oil ( not ordinary engine oil as for cars )and the ratio is 40:1
the engine type is a homelite engine and the ratio can be 40:1 or 50: 1
I prefer to set the ratio as to the smoke produced so if 40:1 produces too much smoke at full rpms , drop it back to 50:1
The correct mix is when there is JUST visible smoke at rpms
definitely no e fuels.
Jun 25, 2016 • Garden
1helpful
What type of motor oil does the Tao Tao use?
If it is a 4 cycle engine the engine oil is 10w40 oil designed for use in a motorcycle not automotive oil. it is a 4 cycle engine if it has a dipstick near the muffler to check the engine oil.
Feb 22, 2015 • Motorcycles
What type of gear oil do I use in my 500 vulcan
you use 10w40 or 20w50 motor oil in this if you talking about engine if your talking about differential oil then its 80 weight oil.
9helpful
2answers
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 • Garden
3helpful
What oil type to use when changing engine oil in a c50 boulevard?
Standard oil to use id SAE10W30 or SAE 10W40.
If you are still in doubt go to your local motorcycle dealer and ask the question as the normally are willing to tell you the oil type for your particular bike. Good enough?
May 21, 2010 • Motorcycles
3helpful
2003 X-Type: what type of engine oil...
petrol engine
5W-30 meeting Jaguar spec WSSM2C913 A or B
I use Mobil Super FE Special 5-30 but there are many more oils that meet the spec.
don't know if diesel is different
1helpful
What type of engine oil for 1.6 focus zetec 2003
2003 FORD FOCUS 2.0L 4-cyl Engine Code [3]
Engine Oil Grade 1......API* All TEMPS......SAE 5W-20, Engine, with new oil filter 4.3 liters.
Thank you for using fixya and good luck Oil Drain Plug.....17ft/lbs Torque
1helpful
2answers
What type of oil I use
The Remington manual for model 111409-01 states: "This Pole Saw requires lubrication only to prevent rust on the guide bar and saw chain. The saw chain provided is pre-lubricated at the factory. With each use of the Pole Saw apply a small amount of lubricating oil directly to the saw chain (see Figure 8). The oil will distribute itself around the chain and guide bar groove during use?preventing rust. We recommend using SAE #30 motor oil for lubrication and rust prevention."
Top Campbell Hausfeld Garden Experts
Jay Finke
Jay Finke
john h
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
